Convertible top frame adjustment
Old July 6th, 2017, 12:25 PM
Roger60's Avatar
Not sure if I'm in the right category, I have disassembled, painted, and rebuilt the conv. top frame on my 67 Cutlass. Bolts and bushings were all ok and reusable, lubed and put back where they came from. New cables and latch hooks. Top goes up and down well. Waiting for the sun visor mounts which are the other half of the top latch assy. My question is are there any adjustments or things I should be aware of before I turn this loose on the upholstery shop or would a good shop do the final adjustments? Would appreciate anything anyone has run into in the past. Thanks.
Roger60 is offline
Old July 6th, 2017, 01:13 PM
If "IF" you know what you're doing [I DON'T] there are adjustments. I would let someone with experience do it. Every time you move "A" , " B" ,"C" and "D: get out of whack
IMHO it's more of an art than a science
Jamesbo is offline
Old July 6th, 2017, 02:23 PM
I took mine apart for cleaning, painting, and fabricating a couple peices and after I put it back together no adjustments were necessary.
Fun71 is offline
Old July 6th, 2017, 03:08 PM
Roger60's Avatar
67 Cutlass conv frame
It's mostly good, center bow hangs up when opening. Little to no side to side adjustment. Took lots of pictures and have a 65 Skylark for reference.
Roger60 is offline
oldspackrat
July 20th, 2022 07:34 AM
ivmachine
Ninety-Eight
August 12th, 2013 09:56 AM
Tedd Thompson
August 11th, 2013 01:51 AM
oldspackrat
December 21st, 2012 08:27 PM
oldsmobilty
September 27th, 2012 04:26 PM
Quick Reply: Convertible top frame adjustment
