What coil spring compressors work best?
I have been trying to compress the coil springs on my 1956 olds 88 to get them back in. I've used this style with the central thread. https://www.google.com/search?q=coil...GRMPFNydP6K1M:
It did not work very well, I can't get it to compress straight. It always pulls to one side and then unloads the pressure from one of the hooks allowing it to slip off.
I am afraid to buy a set of spring compressors for fear of getting garbage.
What spring compressors have you guys had luck with in the past?
I have two styles that I use... Clearance permitting, I prefer the compressor that clamps to the out edges, bottom view... If that doesn't work well, then I use the one similar to what you have already tried...
I've managed to score one of the factory Burroughs Tool compressor tools that uses the lower control arm and upper shock mount to compress the spring. That is definitely the way to go. Since those are very difficult to find, you can make one with high-strength threaded rod and a thrust bearing or you can get this one from OTC.
Yes, I have the engine and transmission out of the car right now. Whenever I life the lower control arm, the jack lifts the whole car before the spring compresses enough.
Hey Joe, what's the model number on that spring compressor? I found this one here. I realize it's the same picture, just want to make sure it's not a generic picture used.
https://www.amazon.com/OTC-7045B-Fro.../dp/B000GTJ5I8
I just did my front springs on my '70 and what a major pain in the a$$ those spring compressors are. The exterior mount won't work for a front spring. The internal one you posted will work but a) it doesn't fit right, b) doesn't fit well, c) barely collapses enough of the spring and d) kept sliding off the spring making it a relatively scary installation. Regardless, it did work but I would have preferred a better tool. I haven't used it but the one Joe recommended looks to be a FAR better design (and I'm sure if he's recommending it it's good )
Best of luck!
Best of luck!
Best of luck!
Best of luck!
The best part: there wasn't a time where I felt like I was going to kill myself or need to go to the hospital.
With the engine out I have used either 5/8" threaded rod, hardware grade, or 1/2" grade 5 rod with a thick plate covering the lower shock hole in the lower control arm, and the rod going through the upper shock hole in the frame. Most of the time, I use the Harbor Freight tool pictured above, and after I get the spring compressed and straight, I install two straps made of 3/16" x 1" wide steel with the ends bent over to fit a coil and hold the spring compressed while taking less room. I also make sure they are installed where I can remove them easily. By the way, use good grease on the threads of the rod!
I used the spring compressor Joe recommended a few days ago. Worth all $170, I did both springs in a little over an hour. The compressor has cast iron plates like you see in the picture that did not slip or pull to one side. The barrel nut and thrust washer make it really easy to compress compared to the cheaper designs.
Longhorncutlass
March 2nd, 2009 01:53 PM
