Clutch Rod Block Off Plate
Old July 8th, 2016, 03:44 PM
RonFX's Avatar
Guys:
I converted my 66 Cutlass to an automatic transmission and was wondering about blocking off the opening in the firewall where the clutch rod came thru, does anyone know of a part specifically for this or do I just make one myself?
Thanks, Ron
RonFX is offline
Old July 8th, 2016, 04:08 PM
It's part of the lower steering column mounting plate. The LH part of the plate bolts on and there are two designs, one with the hole and one without. Since everyone else is converting TO a manual trans, there are repros of the one with the hole. I would imagine there are a lot of the AT plates around from these conversions.
OK, apparently Motor City Musclecars (the sister company to Inline Tube) sells the AT plates for the 64-67 cars on ebay.
http://www.ebay.com/itm/64-67-A-body...del%3AChevelle
joe_padavano is offline
Old July 8th, 2016, 07:49 PM
Run to Rund's Avatar
FWIW, the 1966 setup used a rubber sleeve around the column, and a one-piece firewall plate with or without the clutch rod hole.
Run to Rund is offline
Old July 8th, 2016, 07:55 PM
2blu442's Avatar
Ron, I may have a used one. My experience is that I've ended up cutting the rubber seal to get the plate off. I've not glued one back together but figured that's what would need to be done. John
2blu442 is offline
Old July 8th, 2016, 09:33 PM
70Post's Avatar
I have one from a '67 but according to you guys the '66 is a one piece. ILT must think otherwise (unless T400 is different and used the 2 piece like I have from a '67).
Mines a steal compared to the repro piece and includes replated original attaching bolts to boot!
Link to my ad:
https://classicoldsmobile.com/forums...ent-parts.html
70Post is offline
Old July 9th, 2016, 07:06 AM
Link to my ad:
TH400 wasn't offered on the 66 A-bodies
Old July 10th, 2016, 11:20 AM
RonFX's Avatar
Guys:
Thanks for the replies and information, once again you are a wealth of knowledge.
Thanks, Ron
RonFX is offline
CutlassLegend
August 13th, 2011 08:10 PM
mmcilroy
August 26th, 2010 08:42 AM
Mongoose
December 4th, 2009 05:11 PM
66ninetyeightls
November 2nd, 2009 05:03 PM
Redog
December 14th, 2007 01:17 PM
Quick Reply: Clutch Rod Block Off Plate
