body mounts
Old May 13th, 2016, 06:19 PM
a70oldscutlass's Avatar
body mounts
I need some help.I bought the energy suspension poly body mounts before they come out with the olds ones and I need to know which one goes in what hole.I would sure be gratefull for the help.thanks
a70oldscutlass is offline
Old May 29th, 2016, 07:30 AM
Krom's Avatar
my kit had directions that showed what mount went in what spot, using the numbers molded into the mount
Krom is offline
Old May 30th, 2016, 08:59 PM
I left part of my problem out.I bought them for a 70 chevelle because at the time they didn't make them for a 70 olds.
Old May 31st, 2016, 08:52 AM
TripDeuces's Avatar
The only difference between the two might be the radiator support mounts.
TripDeuces is offline
Old May 31st, 2016, 08:58 AM
His kit may not have come with rad. support bushings. A Chevelle is an Abody as is a Cutlass. You may have to reuse some of the original metal parts from your car.
oldcutlass is online now
Old June 3rd, 2016, 07:31 PM
That was the other problem.The car was tore apart years ago and I'm guessing it had hardware that was to be used over that got throwed away and I don't know where to get that hardware kit.
stuart
January 27th, 2020 04:47 AM
joesw31
May 31st, 2015 04:17 PM
Nasty455
March 20th, 2012 04:57 PM
flatoz
March 15th, 2009 02:03 PM
The Pope
July 11th, 2007 06:13 AM
Quick Reply: body mounts
