Wheel Hop Help
Old Jan 15, 2021 | 08:10 AM
Doug Carner's Avatar
69 Ol' Blue
Wheel Hop Help
I have a 1969 442 with a M20 and 3:91 gears. I removed the after market Lakewood ladder bars to perform a factory correct restoration. I did not have a problem with wheel hop before but do now that the ladder bars have been removed. I've read a little about torqueing the suspension bolts without the weight of the car on the suspension. I did just that and suspect that the suspension is binding up. How do I fix this? Should I jack the body up then loosen the suspension bolts or loosen them up with the weight on the suspension before retorqueing?
Old Jan 15, 2021 | 08:22 AM
Sugar Bear's Avatar
Loosen the bolts plenty, with the wheels on the ground bounce the car several times, retighten the components with the weight still on the car.
This is easiest on a drive on lift. My next choice would be to safely put all 4 wheels on equal height blocks to gain some ground clearance. Be certain it is blocked safely and the lower the better.
Good luck!!!
Old Jan 15, 2021 | 10:06 AM
Jeff Stout's Avatar
What your doing is pre loading the rubber bushings and making them stiffer by tightening in place with weight off of them. I would replace with urethane bushings and air bags. No air when cruising. and maybe start with 10lbs of air if racing. The other alternative is the no-hop bars mounted on upper control arms. We have them on a street driven malibu and work well and can be driven daily with no problems. Im sure you are aware that enough wheel hop when launching will break first gear in that trans or spider gears or axle.
Old Jan 15, 2021 | 10:15 AM
I just set the rear diff on jack stands (same as weight on wheels) at equal heights and spaced enough to allow access to the suspension bolts. Loosen it all up and retorque.
Old Jan 15, 2021 | 11:54 AM
69 Ol' Blue
Thanks for all the great advice!
Old Jan 15, 2021 | 01:06 PM
joesw31's Avatar
I doubt that its the torque on bushings. This is a very common problem with stick shift cars. More than likely its your shocks.
Old Jan 16, 2021 | 02:16 AM
Grayghost's Avatar
1) do like stated above, fix the bushing preload.
1b) check all link mounting points for cracks, braking away from frame including the upperlinks crossmember
2) check the pinion Angle is in spec.
3)shocks.
Old Jan 16, 2021 | 08:50 AM
VC455's Avatar
Barely Registered
Did you change tires?
Tires with less traction sometimes hop.
Jerry0726
Wheels and Tires
Jun 3, 2019 09:29 AM
bones
Brakes/Hydraulic Systems
Apr 13, 2017 05:39 PM
Haidda
Mar 27, 2017 08:30 AM
maxsonrj
Apr 16, 2013 06:21 AM
815Cutlass1972
Suspension & Handling
Jul 6, 2010 05:23 AM
