vin # help
If someone could help me dispher thi vin # I would be very grateful !
The car 1969 cutty conv.
ST 69 91667 LAN 269104 A BDY
OLE 51 PNT
WHAT I KNOW 1969 , LANSING, A BODY, DARK BLUE MET.
Any help would be a great help
THANKS JIMBO
OLE 51 PNT
THANKS JIMBO
That's not the VIN, that's the Fisher Body cowl tag and you've already got nearly all the info that's available in it from what you've posted. Note that the "91667" number is not a normal cowl tag number. Check it again. Frequently these numbers are hard to read and a "9" may actually be a "3", "6", or "8". Also, the "OLE" should actually be two digits followed by a letter, so the "L" should actually be a number. This will be your build date. The two digits are the month and the letter is the week. I'm guessing this is actually "01E", which would put the build between the 27th and 31st of Jan, 1969.
