tubular a-arms
Old Jun 1, 2013 | 08:58 AM
joepenoso's Avatar
Question tubular a-arms
best bang for buck, front tubular a-arms
have any of you tried..............
http://www.ebay.ca/itm/400203563039?... 4.m1423.l2649
or
http://www.ebay.ca/itm/170762549972?... 4.m1423.l2649
joepenoso
Old Jun 1, 2013 | 09:12 AM
NHolds's Avatar
I've got one's that look very similar... off Ebay too, but I don't remember the vendor.
They work well, seem to be made well.... definitely beefy....
I put coil-overs with mine to lower, so I don't know how the original spring sets in them.
Old Jun 1, 2013 | 09:15 AM
woodie582's Avatar
Scary, to place your life with those things. Just my opinion.
Old Jun 1, 2013 | 11:33 AM
Rocket Richard's Avatar
Really? Have you heard of these failing at all?
Old Jun 1, 2013 | 12:12 PM
joepenoso's Avatar
This the second time I have posted about this and no accidents or maiming have been reported. After I finish my cam change............ this or swapping the rear end will be my next project. Why did you use a coil over shock?
How different is the handling??
Any deaths to report????
joepenoso
Old Jun 1, 2013 | 12:34 PM
oldstata's Avatar
Justin
These look like the ones I bought I will have to look from but they seem well built have not installed yet
Old Jun 1, 2013 | 12:55 PM
NHolds's Avatar
joepenoso
I used coil-overs because I wanted to modify the ride height. I really didn't know how it would sit with the stock coils, and the stock coils were way too high for my taste. This way I can fine tune it.
Handles about the same actually. I have the 1 1/4" sway bar in the front, and a large one out back.
Old Jun 2, 2013 | 06:57 AM
oddball's Avatar
The ProComps are a direct copy of the Hotchkis arms. They easily accept coilovers and can easily adjust ride height with shims. The main gotchas are the "Delrin" bushings that come with them must have been machined with a hand knife, and the ball joints are highly suspicious. Get a rebuilt kit from Hotchkis and a quality balljoint, and you're well ahead. Yes, one should try to check the welds to make sure everything looks OK. IMO, the tubes and welds will be fine. Everything else (additional components, machining) is suspect but can easily be fixed.
The other pair is the other common copy. The main arm is the same, but the spring seat is very different. You don't get quite as much adaptability with that spring seat. I haven't see one of those pair, so I don't know what other pitfalls await. I would expect the same general concerns.
I talked to Mark at SC&C, and his funny note is calling those bump stops "pretty ice cubes". Once installed, the tie rod will actually hit the frame BEFORE those bump stops. They are also rock hard plastic. So good idea to replace those with something. I'm going to use the SPC progressive bumps that Mark sells.
Old Jun 2, 2013 | 07:14 AM
I've read stories of off brands having ball joint failures, and have personally witnessed a whole range of upper control arm bushing issues of slipping over mounting shaft, splitting, and premature wear.
I'll stick with stock vs the off brands.
Old Jun 4, 2013 | 05:53 PM
oldstata's Avatar
Justin
kmjent.com. This is where I got mine I did a part number search before I bought and today and it didn't have any reviews for the control arms . They seem pretty well built and I did plan on changing out ball joints to a better brand hope it helps
Old Jun 5, 2013 | 06:10 AM
oddball's Avatar
The kmjent arms are the ProComp arms - Hotchkis copies. As noted, take a close look at the bushings. A bushing kit from Hotckis (or Jegs) is about $100 for the lowers.
Old Jun 5, 2013 | 08:09 AM
joepenoso's Avatar
Red face
Look at this set on Evil bay..........................
http://www.ebay.ca/itm/171002078763?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649
it's price is almost too good to be true.
Is it a copy of Hotchkiss .....or....what?
Any of you experts had experience with this outfit or this tubular a arm?
Inquiring minds want to know
thanks
joepenoso
Old Jun 5, 2013 | 08:22 AM
NHolds's Avatar
thanks
joepenoso
Those are the ones on my car... but I didn't buy from this vendor.
Old Jun 5, 2013 | 11:50 AM
$207.00 For upper and lowers, Wow.
Old Jun 5, 2013 | 05:54 PM
oldstata's Avatar
Justin
I bet that all the cheap arms are from same vender ?
at 200 buck, I would at least inspect welds and install better ball joints . I spent like fifty bucks more during the winter sales and plan to Change ball joints.
just my opinion we all like cheap , but in the end it's up to you some people don't mind the china stuff some do
Old Jun 5, 2013 | 08:33 PM
I hope they don't fall into the category of "You Get What You Pay For".
Impin'
Suspension & Handling
Apr 20, 2012 09:36 AM
johnspd22
Oct 29, 2010 07:41 PM
Mikes65
17
Aug 23, 2010 09:43 AM
68fastwilliams
May 7, 2007 07:08 AM
68fastwilliams
Apr 30, 2007 11:33 AM
