Trim and lettering removal
Old Dec 5, 2008 | 10:37 PM
f-85's Avatar
How do i take off the super 88 on my 64 super 88? Im working on sanding it down and prime it.
Josh
Old Dec 5, 2008 | 11:04 PM
rocketraider's Avatar
Oldsdruid
If you're talking about the ones on the front fender, they're held on with studs and tinnerman nuts. You should be able to get to them from underneath the fender, but you may have to drop the fenderwell to get the back one, I can't remember.
What a lot of folks do with hard to access fasteners is use a putty knife and chop the mounting studs off. Then use some 3M molding tape to reattach.
If you can get the nuts off and remove the script with the studs intact, get some speed clips to reinstall. Those push into the stud hole on the fender, then you tap the script stud into them. You can usually pry the scripts off to polish and wax behind them after you install those.
Old Dec 5, 2008 | 11:18 PM
f-85's Avatar
I just found them and came on to post it. Thanks for the putty knife trick. Im sure i will use that one in the future.
Josh
Old Dec 6, 2008 | 01:39 PM
csstrux's Avatar
If you are trying to save the studs you may want to shoot a little cr56 or wd40 on them before you take them apart. Living in Wisconsin, corrosion gets everywhere, and the pot metal seems to get brittle. I imagine it is the same for you unless lockport is in the southern tip someplace.
radman58
Apr 7, 2011 05:21 PM
bobb
Sep 30, 2010 08:53 AM
mv213
Sep 21, 2009 07:25 PM
scrappie
Sep 12, 2009 08:40 AM
Oldsfan
Dec 29, 2006 05:52 AM
