Transmission cross-member
Old May 29, 2016 | 04:13 AM
Inline's Avatar
This might be stupid question, but am i right that any A-body dual-exh. transmission crossmember bolts to 76 Cutlass too? I have duals, but somebody, somewhere didnt change the crossmember, and it looks stupid underneath the car, and when looking enough far away the car and seeing drivers side exhaust going under crossmember. Just to know can i search any year crossmember for me.
Thanks for answer.
Old Jun 3, 2016 | 10:05 AM
Inline's Avatar
Anyone?
Old Jun 3, 2016 | 10:51 AM
76olds's Avatar
Hookers under Hood
Not sure if you want to cut your crossmember and weld it up. If you look at my 76 olds pictures in my profile you can see how my crossmember looks.
Not sure what years interchange but I know others here do.
Hope this helps
Eric
Old Jun 3, 2016 | 10:55 AM
76olds's Avatar
Hookers under Hood
Old Jun 3, 2016 | 11:48 AM
Inline's Avatar
Thanks for pic. Im aware i can do it myself, but im asking this since i wouldnt want
to destroy my original crossmember, instead store it if theres another fitting crossmember which is from factory to duals.
Old Jun 3, 2016 | 12:52 PM
76olds's Avatar
Hookers under Hood
I believe the 73-75 Olds as well as malibu/chevelle, monte carlo crossmembers come to mind.
I hope other guys here can help out some with your?
If you go onto 73-77 olds site and do a search you may come up with something.
Hope this helps
Eric
Old Jun 3, 2016 | 01:01 PM
Hope this helps
Eric
Only the 1973-74 A-body crossmembers are double hump. Starting with the 1975 model year, all came with a converter and single exhaust.
Old Jun 3, 2016 | 02:24 PM
don71's Avatar
same but different
Joe, are you saying yes, he can use an the earlier A body cross member? They appear to be the same length at 53"-53-1/32".
Old Jun 3, 2016 | 02:31 PM
I wasn't sure if 68-72 were the same width as those on the 73-77 cars. If they are, then absolutely. Obviously the convertible/Vista crossmembers are narrower due to the boxed frames.
Old Jun 3, 2016 | 02:51 PM
don71's Avatar
same but different
Also El Camino are too narrow due to boxed frame also.
So an Early A body cross member should work. I can't imagine it would need much modification. Or the 73-74 cross member pre catalyst era would do it.
Old Jun 3, 2016 | 02:54 PM
"Early A-body" is 64-67, and I KNOW those are narrower than the 68-72.
Old Jun 3, 2016 | 03:14 PM
don71's Avatar
same but different
Mr. Semantics wins again. You got me.
Old Jun 3, 2016 | 03:23 PM
Simply trying to make sure the OP gets correct info. Nothing more.
If it's at all possible to misinterpret something on the web, someone will.
Old Jun 3, 2016 | 11:05 PM
Inline's Avatar
Thank you very much, all of you.
Now i think i have good enough starting point to start hunting for one with that narrow list.
Old Aug 5, 2016 | 09:03 AM
Inline's Avatar
Update- while ago made a lucky score for correct crossmember on Ebay when searching what was for sale for my car.
Post and taxes cost more than the crossmember itself, but its money well spend.
WTony
Apr 22, 2015 11:27 AM
Nasty455
Mar 21, 2012 05:51 PM
66ninetyeightls
Sep 4, 2011 07:06 PM
scubastever
May 6, 2010 08:51 PM
Big John 85
Feb 6, 2009 11:01 AM
