Transmission cross member mounting brackets
Old Mar 20, 2012 | 06:27 PM
Nasty455's Avatar
XCELERATIONRULES!
Looking for some help locating the rubber insulators and mounting brackets and hardware for a 71 Cutlass.
If I later swap to a 4 speed do I need a new cross member?
Turbo 350 and turbo 400 share the same cross member?
Thanks.
Old Mar 20, 2012 | 08:20 PM
ah64pilot's Avatar
Thanks.
Cross member is the same for TH350 and TH400. What rubber insulator are you talking about? Are you talking about the rear transmission mount? You can get a polyurethane mount from Energy Suspension for cheap. It comes with all the hardware. The only other thing you will need are 4 bolts for the cross member itself (2 on each end where it mounts to the frame).
Old Mar 20, 2012 | 09:22 PM
btrbill's Avatar
I have never seen a Cutlass with the rubber crossmember insulators. My fathers' 66 LeMans has them, and I know some other GM cars do, but even the 71 Factory Assembly manual does not show them in any application.
Old Mar 21, 2012 | 06:53 AM
Rickman48's Avatar
And there is a series of holes on each side of the frame for various applications - install the trans mount first, and the correct holes should line up.
Old Mar 21, 2012 | 05:51 PM
Nasty455's Avatar
XCELERATIONRULES!
I found the cross member in the trunk...it has no holes drilled in it.
I was assuming it was Pontiac Style and used insulators and brackets.
I'm guessing I can use it with the brackets and insulators?
I thought all the A bodies within the same wheelbase used the same frame.
If not,I will need to locate a correct cross member.
Any pics guys?
Thanks.
WTony
Apr 22, 2015 11:27 AM
olddaz
Aug 27, 2014 06:39 PM
66ninetyeightls
Sep 4, 2011 07:06 PM
scubastever
May 6, 2010 08:51 PM
Big John 85
Feb 6, 2009 11:01 AM
