Torquing the suspension bolts
Old September 2nd, 2016, 10:35 AM
boese1978's Avatar
68 Cutlass, all after market spohn suspension parts- how critical is it to have car level, with the suspension loaded, while tightening the nuts? My garage floor is cracked and uneven, thoughts please?
boese1978 is offline
Old September 2nd, 2016, 12:00 PM
ELY442's Avatar
Can you do it on the driveway, street or just put plywood on your garage floor.
ELY442 is offline
Old September 2nd, 2016, 01:00 PM
TripDeuces's Avatar
It's only important if the bushing is bonded to the center sleeve, as in like the stock rubber ones. If they are poly then you would have had them all greased up inside and out including the faces (yes?) and it is not as important. Same goes if you used a Delrin or johnny joint, not important.
TripDeuces is offline
Old September 2nd, 2016, 01:12 PM
boese1978's Avatar
Cool, and yes, they are lubed, faces as well, with the stuff that came with the kit. "not as important"...how not important?- just curious if it might make the car sit unevenly on level ground. I am guessing my garage floor as a 1-1.5" "slope". Just load the suspension and torque away i guess?
Thanks for the response.
Old September 2nd, 2016, 01:15 PM
boese1978's Avatar
Not my driveway car is not running currently ( exhaust is half in and then time to fire it up) so a bit of a challenge to go find a level spot.
Thanks for the suggestions.
Old September 2nd, 2016, 01:19 PM
TripDeuces's Avatar
Not as important being that being lubed they will find their own center. If they weren't lubed I'd be concerned with binding.
stanzaschance
July 28th, 2015 06:38 AM
Sampson
December 28th, 2014 07:41 AM
nolabigdawg
October 25th, 2014 11:50 AM
Oldssupreme
February 6th, 2013 12:39 AM
Danny Boy
August 25th, 2010 07:39 AM
Quick Reply: Torquing the suspension bolts
