Tailpipe hangers for 2.5 inch exhaust 1970 CS Vert
Old Jun 21, 2024 | 11:35 AM
70Cutrag's Avatar
I picked up a pair of tailpipe hangers from Fusick for my 70 Supreme Vert, but realized they are for 2 inch exhaust, mine are 2 1/2 pipes.
Has anyone found a source for 2 1/2 inch tailpipe hangers, or just have something fabricated at ye old muffler shop?
Old Jun 21, 2024 | 01:51 PM
72455's Avatar
1972 U code Supreme
Inline Tube has them.
Old Jun 21, 2024 | 02:22 PM
I'll check...I may have some (several) in a box. I replaced the worn-out hangers on my '71 CS convertible. I can't recall size - I'll have a look.
Old Jun 21, 2024 | 02:37 PM
I have some Nickson 2.25" clamps & some HD hangars.
Nickson sells 2.50" HD Exhaust Clamps >>>http://www.nickson.com/newcatalogs/P1-12%20Clamps.pdf
I used a generic HD hangar when I replaced the clamps w/ Nickson clamps.
You can most likely find both the Nickson 2.5" clamps and HD Hangars at your local suspect parts stores.
Old Jun 22, 2024 | 05:29 AM
The 1970 Cutlass tailpipe hangers look like this. Nothing prevents you from using it on a 2.5" pipe. Just get the correct size clamp. Yeah, the radius of the curved portion that fits over the pipe will be wrong. You can flatten it a little with a bench vise.
Old Jun 22, 2024 | 10:17 AM
70Cutrag's Avatar
I think a pic or 2 will clarify my issue. The clamp is 2 1/2 inch and fits pretty snug around the muffler flange. The hanger will only accommodate up to a 2 1/8 clamp. Guess I could round out the holes on each side some, hoping to keep it centered, or just fabricate something different.
Old Jun 22, 2024 | 12:52 PM
That's the muffler hanger, not the tailpipe hanger. I solve this problem with a die grinder or rattail file to elongate the holes until the clamp fits. Been doing it that way for 50 years now.
Old Jun 22, 2024 | 02:07 PM
70Cutrag's Avatar
Thanks for the reply
Joe.
OK, I,ll give it a shot. It looks like that left side hole is going to be blown out in order to keep the clamp centered on the pipe and hanger.
Old Jun 22, 2024 | 02:27 PM
You can grind that notch also. Note that the other part of the clamp likely sticks down further than that flange on the bracket anyway.
zekecut70
Jun 17, 2021 11:28 AM
Sep 2, 2020 05:16 AM
Gary M
Oct 30, 2014 08:05 PM
antweave
Nov 26, 2011 08:49 PM
