Suspension Help NEWBIE
Hey there olds folks, I just got my front end suspension kit in today, Ive never dealt with the suspension before i have a chilton manual but its entirely to vague. This is what the kit contains.
http://www.ebay.com/itm/170922039810...84.m1439.l2649
Its a front end Rebuild kit what would be a good place to start. Thanks Guys
Not sure what year and model you are fixing to do, but if a 69-72, check out my "front end job" link below. Read through and enjoy.
The job is not that bad, only when you know how to do it. I had to learn as I went.
Hare are some pictures of the control arms if this helps you at all. I also see that you have the push in bushings for the upper and lower control arms. you will need a press for those. 100_2567.jpg
You need a factory shop manual. Be very careful how you remove the springs, they can kill you. You may want to have a shop do the control arm bushings, everything else is hard work but easy work. Now is the time to replace your front springs if needed. Good luck!
As long as the engine is in the car, everything here should work fine for you...
https://classicoldsmobile.com/forums...tml#post264807
Keep us posted on your progress!
been working on it since 6am my time used the jack to release the springs slowly no bodily harm incurred, encountered one problem the previous owner put 1972 spindles and discs on it so my tie rod ends are a little short but the pin goes threw the nut so its okay, also the lower control arm bushing they sent was wrong one is circle and the other is oval but they sent to circle ones so gonna have to have them send the right ones.
replacing springs and shocks looks like the old shocks had dragged the ground at one point and the previous owner just hooked them back up thank god im doing this doesnt look like the suspension would have made it much furhter.
the control arms are in great shape minus the bushings
shocks and tierods and sway bar bushings are completley shot. will pust pics of the old stuff later on
yeah im gonna need sway bar bushings as the kit didnt come with them, cant wait till my car looks that shiny need to order some paint so everytime i pull parts off i can paint them.
The correct 1964-72 outer tie rod end looks like this:
Last time I changed those I got them from the local auto parts store.
NAPA shows a variety for different sway bar thicknesses:
http://www.napaonline.com/Catalog/Re...0052%2b2052017
If you want polyurethane then you may need to order them from PST or a similar company.
dprestia
Suspension & Handling
17
Oct 20, 2014 07:34 PM
noeatnosleep
Jul 2, 2011 12:30 PM
henryk8398
Feb 22, 2010 08:54 AM
