Steering column replacement issues:
Old Sep 29, 2019 | 07:10 AM
OldsFan307's Avatar
Exclamation Steering column replacement issues:
After 31 years, my 1988 Cutlass supreme classic (G Body) requires a steering column replacement. This year was the last year that Oldsmobile produced a rear wheel drive Cutlass Supreme (Classic) with a V8 engine.
I purchased a re-built steering column only to find that the diameter of the steering wheel shaft is a different size and shape that the original intermediate steering shaft assembly, so now I can't connect it.
The column supplier says that they are a standard size 1" DD. and the clamp may be compacted into a slightly smaller diameter, But If that is true, than why is mine different. Instead of a spline & clamp type my old steering column connection has sort of an 'oval" look to it.
Has anyone else had this issue?
Hopefully I can get a new rag joint with the new diameter or a complete new intermediate steering shaft assembly and problem solved.
Does anyone know why my car has this setup? Vehicle is a 1988 Oldsmobile Cutlass Supreme Classic Brougham, Rear wheel Drive V8 307.
Any info would be helpful.
bobmobile
Apr 18, 2015 08:51 AM
webby
Suspension & Handling
38
Jan 5, 2013 02:49 PM
98 man
Mar 3, 2012 03:32 PM
68conv455
Nov 19, 2011 07:36 AM
Stevec
Aug 4, 2011 08:36 AM
