Shell and Frame seperation
Old Jan 21, 2014 | 05:36 AM
CajunCutlass's Avatar
It's probably already been mentioned but I am trying to seperate the body from the frame of a 1970 cutlass, and was wondering if anyone can tell me the exact location of the bolts i need to remove?
Old Jan 21, 2014 | 08:39 AM
kitfoxdave's Avatar
The locations of the body mounts are in the Chassis service manual. Check wild about cars for a freebee download, or even better by one on ebay (worth it just for the schematics!) but virtually everything you need to know is right in there....
Old Jan 21, 2014 | 09:22 AM
Octania's Avatar
Did you saw off the two at the core support already?
Just look for the obvious access holes in the frame- usually 1 or 2 to twist off at the very front, at the bottom of the firewall.
Then snap off the two around the front seat area.
Farther back is probably just pads w/o bolts.
Then break off the cage nuts on the two at the very back.
Might need to destroy a couple at the front of the trunk also.
Or, if you are in Cajun Country, maybe bolts just unscrew for you there.
Per this ad here, there are up to 10 with bolts and 2 pads
http://www.ebay.com/itm/1968-72-Olds...f5b0d6&vxp=mtr
Old Jan 23, 2014 | 08:36 AM
jfb's Avatar
jfb
soak them for weeks everday with power blaster it will really help and i mean A lot of it like maybe a can a day.
Old Jan 23, 2014 | 08:50 AM
66400's Avatar
Just pulled a 71 Cutlass frame yesterday. Eight bolts total, 2 at fire wall with 1inch square nut, rest of bolts have caged nuts. 2 bolts mid section under door, 2 bolts behind rear wheel and 2 bolts at very end of frame. Texas car so all bolts came out using 3/8 drive rachet! Frame bolts use a 5/8 socket.
Henry
Old Jan 26, 2014 | 11:09 AM
jfb's Avatar
jfb
I like the southern car easiness but northern cars can be a b--ch.
Old Jan 27, 2014 | 05:09 AM
RonFX's Avatar
body mount bolts
66400:
Sounds you are bragging about only needing a 3/8 ratchet set to remove yours, all of my bolts from an Ohio car twisted off or spun in their cages and required surgery to remove! LOL!
Ron
Old Jan 27, 2014 | 09:49 AM
66400's Avatar
Originally Posted by RonFX
66400:
Ron
It's the luck of the draw, sometimes it's easier than others. Some of our rusty cars down here with rusted out trunk or floorboards will give me a workout.
Henry
Propaneking
Care and Appearance
Jun 30, 2015 07:09 PM
jbichko1970S
Dec 12, 2014 02:31 PM
brandon reynolds
Jun 13, 2013 01:19 PM
1969goatman
Aug 28, 2010 08:36 PM
skip79
Aug 27, 2010 09:06 AM
