Removing the body from the frame
I can't believe we are getting ready to pull the body off the frame, but we are and I have a couple of questions. It's a 71 convertible with not to bad of rust, floor is in pretty good shape, not rot around windshield, etc. The top is still onthe car, but I've got the latches off the front so it's just hanging there.
Our plan is to do what others have done and bolt a piece of angle iron to the hinge mounts and run a piece of 1 inch square tube from each to the door striker. Question, what thickness do I need for the angle iron and for the tubing? Second, what's the best way to attach the tubing to the door striker or is it better to attach it to the inside of the door opening?
Do you guys brace across the car? My son is thinking we should use two pieces of tubing diagonally from door to door. What do you guys suggest.
The tank is out, front end and suspension is off, engine and trans are out. Interior except dash is out as well as bumper, trunk lid. Os there anything else to remove other than the parking brake cable?
I'm planning on setting it on 4x4s and concrete blocks.
Thanks for any and all tips!
I used roughly 3/16 inch plate and angle iron. For the striker part I took a piece of flat stock and bent it into a 90* angle. The I drilled a hole in it, removed the striker bolt and bolted the plate behind the striker bolt. I also made another plate that bolts to the hinge holes using the original bolts. I welded a piece of angle iron between the plates. The upper brace is just welded to the angle iron and tacked to the door edge. I did not brace it across the body although that's an option.
Maybe this would be better?
1969goatman
Aug 30, 2010 07:44 PM
