rear upper control arms
Old Nov 2, 2016 | 11:39 AM
jwr7042's Avatar
I have changed everything in the rear and am still have wheel hop. the upper arms are adjustable and are all the way in. I know that the rear pumpkin has to be level or slightly pointing down, but how do I get it that way. What length are the upper arms?
Old Nov 2, 2016 | 03:28 PM
Olds442redberet's Avatar
What components did you use. And post pictures.
Old Nov 2, 2016 | 03:37 PM
The rear end setup is based on pinion angle. X2 on pictures. What springs, shocks, tires, and gear ratio.
Old Nov 2, 2016 | 05:59 PM
oldolds88's Avatar
on my circle car,we would shorten the uppers. using large washers,with new holes to move the top of the pinion down,usually shorten about 1/2" would get it where ii wanted. this was after lowering the springs(race springs),and having the lowers level to the ground
Old Nov 2, 2016 | 07:30 PM
jwr7042's Avatar
pinion angle
I have completion engineering trailer arms with top adjustable. the uppers are adjusted all the way in. to adj out would lift the pinion up. I put new moog springs. and 3 way adjustable shocks. I also have a comp eng drive shaft. can't get underneath when on ground. Will find a drive on hoist to try to get pictures. I understand the pinion angle is the main cause but do not no how to fix it.
Magna86
Jun 4, 2014 10:16 PM
rcktdoc
Nov 4, 2013 05:06 AM
joepenoso
Suspension & Handling
19
Nov 1, 2013 03:05 PM
RetroRanger
Apr 5, 2013 10:23 AM
