Rear Upper Control Arm Bushings....HELP
Old January 9th, 2012, 05:52 AM
1970 Cutlass Convertible
frasco's Avatar
I have a 1970 Cutlass
Can anyone confirm that the rear upper and rear lower control arm bushing are the same part?
I phoned Rock Auto and they show them to be the same Moog Part # K5161
I thought the rear upper had a stop so that the bushing would not go all the way thur the "ear" on the rear end>
Scott
frasco is offline
Old January 9th, 2012, 07:56 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Should all be the same thing.
Sleeve, rubber, shell.
J-(Chicago) is offline
Old January 9th, 2012, 08:39 AM
Run to Rund's Avatar
All the same part number. They have a small shoulder as you described. The end with the flange is bigger than the other end, and the holes in the arms correspond. The step serves as a stop for the ears in the diff. housing.
Run to Rund is offline
ithaca4me
July 30th, 2011 02:26 PM
mcutlass1969
August 2nd, 2010 11:27 AM
bigwillystyle
December 21st, 2009 10:05 AM
therobski
October 24th, 2009 01:54 PM
tiparosa
February 26th, 2007 10:43 PM
Quick Reply: Rear Upper Control Arm Bushings....HELP
