rear tires ... 69 442
Old Jun 22, 2009 | 11:31 AM
Bob Lynch's Avatar
what is largest tire I can put on my 69 442 convert? at show Sun., a guy had some M T street radials ... 295 65 15s ... wonder if they will fit under the wheel wells with out interferrence ... can someone enlighten me please? Bob Lynch ... also, is any one running the Toyo street radials? how do you like them?
Old Jun 22, 2009 | 12:57 PM
Oldsguy's Avatar
Past Administrator
No need for you to post in the newbie section any longer. I moved your thread for you.
Old Jun 22, 2009 | 02:30 PM
295/65-15s are over 30" tall and nearly a foot in section width. That's pushing it on an unmodified 69. You would likely need to roll the fender lip and would still need custom offset rear wheels. A 30" tall tire will also somewhat negate your rear axle ratio, since the taller tire is equivalent to installing lower-numerical rear gears. For example, if your original tires were 26.5" in diameter (say, a 245/60-15), expect a 13% reduction is effective rear gear. That's like changing from 3.42:1 gears to 3.00:1 gears while keeping the tires the same.
Old Jun 22, 2009 | 03:54 PM
ent72olds's Avatar
Registered Luser
I can tell you that I have a '72 Cutlass which I believe would have the same demensions as your '69....I have 275/60/15 on the rear. They look like they were born there...not too big! I ran against my brother on the highway and the speedo was still very close (within 2-3 mph), but I can tell you, it didn't help my bottom end. Could run 100mph at half pedal with no problem though. Stock rear, pegleg.
Old Jun 22, 2009 | 04:49 PM
derek nesdoly's Avatar
olds..older..oldest
1969 442 tire size
Like Eric , I'm running the same size 275/60 Ri5 [Yokohamas].Ran a thread a week or so ago about rear tire rub. Tires on Wheels Vintique rims .Had to change rear coils to those from a 1970 Olds 98,and gained 2+ inches of space.Then noted the car's right front was a bit out of level which raised the left rear a tad, so new front coils next. The car over all still has a nice level look,and just came in from a mixed road[rough/smooth] rip and had a] good handling and b] no tire rub.Already had as big a backspace as possible without hitting the undercarriage [as suggested on that thread I started]. I think Joe's point is crucial to what you decide you want your car to do.Like Eric ,I was easy 1/2 throttle cruising at good speed ,but MAY not be able to beat that pesty neighbour in his Chevelle SS....smaller rears and rear gears over 3.42[mine=3.23]. Good luck and post pics!!..........Derek
Old Jun 22, 2009 | 05:25 PM
svnt442's Avatar
Nope. The 68-69 rear quarters do not have to room that the 70-72 cars do. The 70-72 Cutlass bodies have the most room of any A-body.
Old Jun 22, 2009 | 05:49 PM
ent72olds's Avatar
Registered Luser
Like I said, I believe they are , not positive....from the inner wheelhouse to the inner lip of the wheel opening(dead center in the opening, measures 13 7/8 inches. You could measure you '69 to see how they compare if you wanted to run this size tire. Clearance is not an issue at all on this particular year. I'm running the tires on SSII's 15x7's. Hope this helps!
Old Jun 25, 2009 | 02:36 PM
Bob Lynch's Avatar
hey guys ... thanks to all for your feedback ... BOB
jnaarnold
Sep 12, 2017 08:09 PM
navvet
Feb 3, 2014 02:44 PM
oldsguybry
Wheels and Tires
19
Feb 16, 2013 09:14 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
montvaleplace
Sep 20, 2009 12:05 PM
