rear control arm bushing
Old Oct 21, 2009 | 05:26 PM
t bell's Avatar
PITA to get in. I froze both bushings and still can't get them in. I got one to go in but it's not in all the way. The other just wouldn't go. I'm using a regular hammer and a block of 2x4 to get it in there. What am I doing wrong? Is there a video somewhere that shows installation of these bushings? What about a C-clamp?
Old Oct 21, 2009 | 06:47 PM
70Post's Avatar
On the differential housing ears they don't go in "all the way" as there is raised lip around the metal bushing shell and you put them in until this lip hits the opening in the differential ear.
On the control arms you will likely not get them in with a hammer. Go to Autozone, etc and rent/borrow (they "rent" it to you and give you your $ back when you return it) a bushing press setup.
It's also better if you make or use some sort of spacer on the control arms to prevent them from collapsing when you press in the bushing.
BE CAREFUL if you are trying to hammer in the bushings on the differential housing...you can snap those "ears" off.....better done with a press also.
Old Oct 21, 2009 | 08:40 PM
t bell's Avatar
Got it. Just had to give it a few good whacks and more lube.
Old Oct 22, 2009 | 08:49 AM
junior supercar's Avatar
like Patton said, rent the ball joint c-clamp from Auto-Zone or a similar place. Works like a charm to R&R bushings in the rear end housing, you'll just need to make some spacers
Same thing with front and rear control arms, spacers will be needed so the ears of the control arm don't collapse while R&R the bushings. The spacers can be sockets, pieces of metal stock. I've even used wood, although you'd need a lot of wood since they kept splintering and breaking on me.
Old Oct 22, 2009 | 09:13 AM
My442's Avatar
First purchase = car
Second purchase = shop manual
Old Oct 22, 2009 | 09:33 AM
t bell's Avatar
Yeah but the shop manual I have doesn't explain how to do things. What shop manual do you recommend?
Old Oct 23, 2009 | 08:26 AM
The Oldsmobile Chassis Service Manual for the year of your car, which I'm guessing is a 72 based on avatar, wouldn't be a bad idea to get
sqeeek
Jan 21, 2014 09:36 PM
costpenn
Suspension & Handling
18
Apr 20, 2012 03:04 PM
costpenn
Oct 9, 2011 03:43 PM
oregontopcat
Mar 24, 2011 07:17 AM
tim72
Drivetrain/Differentials
Apr 3, 2009 09:00 AM
