Power steering issue
Old Jul 3, 2021 | 08:15 PM
Reese Neis's Avatar
So on my 81 cutlass my the pressure line on my power steering went out and the pump went out so I replaced them both but I still don’t have power steering and I don’t know why I’ve bled the system a couple times now and still nothing anyone have ideas on what’s going on it does have a hydraboost system
Old Jul 4, 2021 | 10:43 AM
Someone had a similar issue recently and it was caused by the pressure valve being installed backwards. The valve inserts where the pressure hose connects to the pump.
Old Jul 4, 2021 | 11:49 AM
Reese Neis's Avatar
ok but another issue devolved now where it’s pushing a steady stream of fluid outta the bottom of the pump is what it looks but I don’t know from where none of the fitting on the back of the pump are leaking and none of the hoses are either
Old Jul 4, 2021 | 01:03 PM
rocketraider's Avatar
Oldsdruid
Reese, I think you got a bad pump. Sounds like the o-ring that seals the pump body to the reservoir has failed. Possibly the pump shaft seal. Is it a used pump or a rebuild?
Only difference in a Hydroboost pump and regular pump is the Hb return nipple on the reservoir. Are the power brakes working?
For the record, I had to replace the PS pump on my Hydroboost Custom Cruiser and returned the first two rebuilt pumps due to leaks. 3d pump was the charm. And natcherly my labor and aggravation didn't count for anything. These were NAPA pumps, too...🙄
coled18
Apr 7, 2021 04:56 AM
rpinnt
Jul 20, 2018 10:49 PM
edzolz
Apr 22, 2018 03:42 PM
mid-life-olds
Apr 17, 2014 04:00 PM
Nasty455
Jan 18, 2014 05:20 AM
