Pitman arm bolt torque
Old Jul 14, 2019 | 02:03 PM
72442455's Avatar
Joe Ralph
I’ve got the torque spec in the csm - my question is ... do I just turn the steering gear to the stop and use it to hold the pitman arm while I torque it? Or will that screw up the innards of the steering box? ~ thanks all
Old Jul 14, 2019 | 04:07 PM
If you are talking about the nut that holds the pitman arm to the steering box shaft, yes, all I've ever done is turn the box all the way to the stop and torque it. At 180 ft-lbs, you don't want to be reacting that load with the lock pin in the steering column. If, however, you are talking about the nut that holds the center link pin to the pitman arm, at 35-45 ft lbs I just use the steering column lock pin and it works fine. No ill effects.
Old Jul 14, 2019 | 06:05 PM
72442455's Avatar
Joe Ralph
Thanks Joe
cdrod
May 3, 2015 08:37 PM
dbuck
Mar 29, 2014 11:01 AM
Napoleon1991
Sep 17, 2013 09:25 AM
Cutdawg78
May 17, 2012 08:18 PM
defiant1
Jan 26, 2011 03:54 AM
