Pinion Angle questions
Old Apr 26, 2012 | 08:43 AM
boese1978's Avatar
As I start work on the rear suspension, and I read about the process etc. I am wondering if it is easiest to tear down one side, install the new CA and then move to the other side to avoid messing with the current angle. Also wondering if some one can explain why the angle can change when the CA's, which control attach to the rear end, only attach one way.
Thanks!
Old Apr 26, 2012 | 08:48 AM
compedgemarine's Avatar
unless you are installing aftermarket control arms that are adjustable there is no way you can change the pinion angle.
Old Apr 26, 2012 | 09:41 AM
boese1978's Avatar
That's what I thought but wanted to confirm. They are aftermarket but non-adjustable.
L77F85
Oct 1, 2013 07:16 AM
STLCRZY
Drivetrain/Differentials
Jan 22, 2011 06:48 AM
raymondh36965
Mar 24, 2010 06:10 AM
geckonz08
Feb 4, 2010 02:28 AM
nonhog
Aug 25, 2009 03:59 PM
