Original control arm bolts... diff style?
Here are a few rear control arm bolts I did not throw out. The one with two washers might be a replacement I put on 15 or so years ago (I recall at least coating it with anti-seize at the time), but the other with the bigger washer type head appears to be original. Anyone else see these types before? I don't recall if it came from the upper or lower arms.
![](http://oldz442.com/images/misc/auto/olds/resto/DSC01360.JPG)
If you look at the assembly manual they're all the type in the pic on top except for the lower rear control arm front bolt which is the hex flange type pictured below it.
My Vista Cruiser has all original fasteners and that's the way it is.
They don't show washers on any of them in the book.
My rear lower arm bolts looked like yours, sans the washers.
Here is what I found early this year:
https://classicoldsmobile.com/forums...tml#post167878
The ones with the rounded washer-like head were on the frame side.
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Just the two on the front of the lower control arms that type on your car too Rob?
AMK has the flange and regular type bolts if anybody needs any.
http://www.amkproducts.com/default.htm
That's a hex head flange bolt.
Oldssupreme
February 6th, 2013 12:39 AM
oldzy
Suspension & Handling
June 12th, 2010 10:02 AM
tim72
Drivetrain/Differentials
April 3rd, 2009 09:00 AM
