Mismatch front springs
Old Aug 20, 2020 | 06:43 PM
oldsmoboogie's Avatar
Does anyone know why someone would put mismatch springs on the front of a car? While tearing down the front suspension on my 64 this is what i found. The longer one was in the passenger side.
Old Aug 20, 2020 | 07:02 PM
Well, that's special.
Old Aug 20, 2020 | 08:00 PM
Maybe because 1 broke they performed a hasty repair. Its hard to tell what goes on with these old cars over the years and what they were thinking when they did it.
Old Aug 20, 2020 | 08:04 PM
RetroRanger's Avatar
72 Olds CS
trying to combat the A body lean ?
Old Aug 20, 2020 | 11:28 PM
v8al's Avatar
Registered Olds Owner
Agree - Maybe broke a spring at some point in time and just threw a single junkyard spring into it.
Old Aug 21, 2020 | 04:59 AM
68442's Avatar
I vote This, I have seen that done before.
Old Aug 21, 2020 | 09:38 AM
Wouldn't it have been easier just to throw a spacer in the lower side then throw another spring in there with a spacer?
Old Aug 21, 2020 | 11:56 AM
I'm thinking the car used to race tight ovals. The passenger spring has 12 coil turns, the driver spring has 8 coil turns. In a constant left-hand turn oval track running 100+ mph that coil spring setup would most likely provide better handling dynamics.
Old Aug 21, 2020 | 03:36 PM
Or there was a very heavy person on one side of the car...
Old Aug 21, 2020 | 03:45 PM
That was my next suggestion...
Old Aug 21, 2020 | 04:33 PM
Sugar Bear's Avatar
It was a COPO heavy duty suspension one side only...very rare.
Seriously though did it sit level? Is the frame racked or bent?
Old Aug 22, 2020 | 05:25 AM
It did not have the engine in it when i got it. No sign of damage anywhere.
Old Aug 22, 2020 | 08:15 PM
I had considered that possibility early on, as well....Mamma liked her beer and ate pizzas by the dozen.
Old Sep 3, 2021 | 05:09 PM
harleyrules's Avatar
The cheapest and easiest way to raise the rear is put in air shocks. Adjust to the height you want.
Old Sep 3, 2021 | 07:13 PM
No it's not, that's the worst way to raise the rear. The upper shock mounting point will not survive the sky jacker route. The easiest and most inexpensive is a spacer under the springs, the correct way is to use the proper springs.
Old Sep 3, 2021 | 10:47 PM
I agree. My experience is air shocks give a stiff, bumpy ride. The more air (higher lift), the stiffer the ride. The right springs give a smooth, comfortable ride.
Old Jan 15, 2023 | 03:22 PM
pclocksin's Avatar
looks like they may have been the same and part of one broke off?
Old Jan 15, 2023 | 06:19 PM
That original post is from 2 1/2 years ago. In any case, look again. They are not the same. The upper spring in the photo has more coils per inch than the lower spring, which means that the upper spring is somewhat softer. I bet they had close to the same ride height.
Old Jan 16, 2023 | 10:40 AM
rocketraider's Avatar
Oldsdruid
Was the 64 in question a factory airconditioning car?
BillJack
Jul 28, 2016 12:26 PM
olds68442
Aug 9, 2015 03:50 PM
Napoleon Solo
Suspension & Handling
Jul 5, 2015 10:36 PM
rpinnt
Mar 23, 2015 06:22 AM
kbdecatur
Jan 9, 2013 03:16 PM
