Large battery tray question
Old Feb 21, 2017 | 08:14 AM
RROLDSX's Avatar
I recently removed my rusty small battery tray and unintentionally ordered the large replacement tray from Parts Place. It will not fit properly parallel to the length of the car but will likely fit at 90*. Was the larger tray an option in 1969 A body? If so does anyone have a pic of how it was mounted? None of the bolt holes will line up either way I mount it.
Old Feb 22, 2017 | 05:58 AM
RROLDSX's Avatar
Instead of sending the tray back, I'll drill some holes and try it at 90*. I'll post pics once I'm finished or report it didn't fit. It'll be awhile. Another reason I thought I'd try it so that I can have the option of using a larger battery.
Old Feb 22, 2017 | 06:07 AM
tru-blue 442's Avatar
Old School Olds
I know there were 2 trays available. One for the b/b & 1 for the s/b.
If I could get the hood open on my 69, I would shoot you a pic. (400 ci)
Old Feb 22, 2017 | 06:17 AM
timholliday's Avatar
Member
This is the best photo I could find with the large battery tray. It will fit on the core support without modification. Two bolts go into pre threaded holes in the core support.
Old Feb 22, 2017 | 08:47 AM
RROLDSX's Avatar
Tim:
My battery tray holes do not line up with the core holes. Also, have you tried to see if your wheel well liner will fit now? That is why I am considering turning the battery. Nice car BTW!
Old Feb 22, 2017 | 09:57 AM
Originally Posted by RROLDSX
Tim:
Then your battery tray is wrong. The BBO cars all got the larger battery and larger tray. This is why the washer tank is on the passenger side inner fender - it conflicts with the larger battery.
Old Feb 22, 2017 | 10:09 AM
RROLDSX's Avatar
Thanks Joe,
I had suspected the battery tray I received may be incorrect, that is why I was asking if it even an option. However my 1969 442 has the wash fluid reservoir on the driver side.
Randy
Old Feb 22, 2017 | 10:31 AM
Old School Olds
Thanks Joe,
Randy
Ditto, mine as well. May have to do with auto trans or possibly assembly
plant? Mine is a Lansing built unit, auto, a/c, pwr. drum brake hardtop.
Old Feb 22, 2017 | 02:04 PM
Member
No problem with inner fender well. Washer fluid reservoir on drivers side.
Old Feb 22, 2017 | 02:09 PM
RROLDSX's Avatar
Wow! What an incredibly nice job. Beautiful car, I like the one in he background as well. Just to confirm, that is the large battery tray you have? Also, is it from PartsPlace?
Old Feb 22, 2017 | 04:41 PM
Member
I think I got it from Fusick. It is the large battery tray.
Old Feb 22, 2017 | 04:57 PM
Member
Here is a better photo.
Old Feb 22, 2017 | 05:08 PM
RROLDSX's Avatar
Perfect. Thanks so much!
Old Feb 22, 2017 | 05:57 PM
RROLDSX's Avatar
Only other problem is after seeing your workmanship I'll never be happy with mine. Good thing the hood will hide my sins.
69442murph
Aug 13, 2014 06:50 AM
71 Cutlass
23
Mar 7, 2011 03:35 PM
silverriff
Mar 29, 2010 09:22 AM
bcracing
Oct 14, 2009 11:04 AM
Kaline
Feb 5, 2008 08:08 PM
