Inner Fenderwells
Old Apr 12, 2025 | 12:47 PM
72Vert442's Avatar
Inner Fenderwells
Does anyone sell the inner fenderwells with the seals already stapled and attached for a 72? If not, how do you staple the seals to the plastic?
Old Apr 12, 2025 | 02:16 PM
dc2x4drvr's Avatar
The fender well seals usually are shipped with the required staples.
Old Apr 12, 2025 | 05:49 PM
scrappie's Avatar
You have to line up the holes and manually insert each staples through both then bend them over and hammer/dolly them flat.
Old Apr 13, 2025 | 05:22 AM
oldoldss's Avatar
There may not be holes and if there are dimples, they may not be in the right spot. Lay the seals out on the inner fender to check. I replaced some years ago and had to drill my own pilot holes in the correct spot for the staples.
Old Apr 14, 2025 | 06:16 AM
oddball's Avatar
If you use the thick staples supplied with the seals then you'll need to drill holes in new plastic inner wells.
On this latest go-around I just used a normal T50 staple gun. Held cardboard over the other side to catch the staple then folded the ends over. Not "correct" but much easier and I put several extra staples in there. My last set of flaps were also too small causing them to tear, so I cut a set out of masticated rubber.
Old Apr 14, 2025 | 10:38 AM
VC455's Avatar
Barely Registered
I made staples out of tinned copper wire that was the same gage as the supplied staples. I placed them through small holes I drilled in the rubber, using the inner fender holes as a guide.
It was much easier to crimp them than the steel staples. There's no corrosion and all is still in place, looking good, 20 years later.
Old Apr 14, 2025 | 03:27 PM
cdrod's Avatar
Rodney
I taped the new flap to the fender liner with blue painters tape, then with a 1/16" drill bit, I carefully drilled through the rubber flaps using the existing holed in the plastic fender liner. My kit did not have enough staples so I had to reach out to the manufacturer and they sent me some more. I like VC455's tinned copper suggestion as the staples in my kit were very brittle and several staples broke when folding them into position.
Rodney
Old Apr 14, 2025 | 05:02 PM
tkcutlass's Avatar
They shorted me on the staples as well and refused to send more.
I ended up buying https://www.ebay.com/itm/331848209319 and paying the 10 bucks shipping for probably less than a buck to send them
Okie Rocket
Apr 8, 2021 06:55 AM
72455
Body work
33
May 30, 2019 08:03 PM
Rustbucket2
Apr 1, 2016 04:46 PM
Amirax
Jan 22, 2016 01:14 PM
69442
Jun 4, 2015 05:25 PM
