HELP 64 Starfire front A arm bushings
Old May 25th, 2009 | 07:45 PM
64starfire's Avatar
Well I picked up my starfire and drove it for the first time. Has some quirks but nothing too major except!!!
I happen to eyeball the front bushings and holy crap!!! they're all shot. The uppers are worse than the lowers. I happened to notice how close the uppers on the drivers side are to the exhaust....pppfftt nice!
Anyhow, so I've searched Moog, ESPO, Kanter, etc etc, and can't seem to find clarity. From what I understand the F-85 is different than the starfire, it was the same, that'd be nice. Ok then I came across this
http://cgi.ebay.com/ebaymotors/64-66...4506.m20.l1116
And I don't know if they're saying this part number is all the same for all those cars? If so I'd order Poly bushings as replacements.
I only have 3 weeks before I leave back overseas so I'd like to get this fixed ASAP.
Can someone enlighten me on crossover part numbers? or anything?
thanks in advance.
Old May 25th, 2009 | 08:32 PM
Danny Wiseley's Avatar
I'm not positive, but I do believe one part number does fit all those cars. I found new bushings for my '64 Jetstar 88 at the O'Reilly's in Levelland, Texas, so they are probably very common.
DW
Old May 25th, 2009 | 08:36 PM
Texascarnut's Avatar
Geezer
thanks in advance.
These are correct replacement upper control arm bushings for your car.
SPICER/RAYBESTOS Part # 5601019
MOOG Part # K6108
There is quite a difference in pricing for the two with the Moog parts running around $10.00 each and the Spicer (probably the same as OE) runs around $5.00. You should be able to get both from any half decent parts store.
The same part numbers would be correct for a JetStar 88 but would be incorrect for F-85.
Old May 26th, 2009 | 09:07 PM
64starfire's Avatar
Lower control arm bushings?
What are the part numbers for the lowers? Those are pretty bad too. I'm having an even harder time finding those.
Old May 26th, 2009 | 11:02 PM
Geezer
Moog does not currently catalog lower control arm bushings for 1964 Starfire
There maybe other vendor options depending upon whether the bushings are oval or round. GM pulled some dumb stunts and some cars were shipped with one type on one side of the car and the other on the other side, or matched on each side.
Old May 27th, 2009 | 02:11 AM
67 Cutlass's Avatar
I didn't have time to look in their catalog for your application but give PST a try.
http://www.p-s-t.us/00001.htm
hotwheels69
April 3rd, 2013 07:48 AM
Bee-Oh-Pee
June 4th, 2012 11:12 AM
frasco
January 9th, 2012 08:39 AM
big_wheel1971
January 23rd, 2010 05:34 PM
therobski
October 24th, 2009 01:54 PM
Quick Reply: HELP 64 Starfire front A arm bushings
