Functional 67 442 Louvers
Old Aug 4, 2008 | 11:13 AM
cbogartjr's Avatar
Hi, has anyone ever made the hood louvers on their 67 442 functional? can it be done? If so how difficult?
Old Aug 4, 2008 | 12:31 PM
442garage's Avatar
Yes, it can be done and has been done. It requires carefully cutting out the panel underneath, and welding a brace between the two rows of louvers. I am having it done to my hood, and I would be happy to provide you with any additional information, pics that you might need. My rationale for doing it is 3 fold. (1) it allows more air into the engine compartment, (2) it allows engine heat to escape, and (3) IMO, it looks better!
Old Aug 4, 2008 | 12:33 PM
442garage's Avatar
Talking
Old Aug 4, 2008 | 01:05 PM
citcapp's Avatar
Your under hood work is the best I have seen outside of a car show. Must have taken some time. I think I am looking at tri power set up is that correct? Great job
Old Aug 4, 2008 | 03:34 PM
Ranzan's Avatar
Getting There
442 garage you wouldn`t happen to know a guy named Larry would you? he is into the 5,6,7s I picked up one of my 67 cars from him in Goldbar a few years back
Old Aug 4, 2008 | 07:48 PM
442garage's Avatar
citcapp,
Thank you for the compliments! I finished a 2 yr. restoration on this car in June. The motor is a N.O.S. stock 455 short block bored to 4.129 and fitted with CP custom pistons, Eagle forged H beam rods, Velasco crank, Comp cams mechanical cam with 568 lift, solid lifters, Miloden 7 qt.pan, Mellings blueprinted high volume oil pump, MSD pro billet mechanical advance distributor, MSD 6AL ignition box and wires, L69 intake manifold ceramic coated with 3 Rochester 2G carbs. Center carbs are jetted to71s and outside carbs are jetted to 73. Edelbrock aluminum heads that have been polished and ported. Doug Thorley ceramic coated headers going to 3 inch stainless steel Magnaflow exhaust. Edelbrock 160gph electric fuel pump connected to a Edelbrock fuel regulator turned down to 4.5psi. Pro race billet dampner and Pro race 9 sprocket timing chain, billet pulleys from Ram Air, custom billet power steering bracket, 4 core aluminum radiator with twin Spal fans, Offenhaueser valve covers,Lakewood bellhousing mated to a Autogear M22 4 speed, Rear end is a 12 bolt with a 3.90 posi.
Old Aug 4, 2008 | 07:50 PM
442garage's Avatar
Ranzan,
Yes, I know Larry.
Old Aug 4, 2008 | 09:33 PM
88 coupe's Avatar
Junior Member
Originally Posted by citcapp
........ I think I am looking at tri power set up ........
........ L69 intake manifold ceramic coated with 3 Rochester 2G carbs ........
L69 tells me that it's an Olds "Tri-Carb" as opposed to a Pontiac "Tri-Power".
This, is one of the nicest I've ever seen.
Norm
Old Aug 5, 2008 | 07:11 AM
442garage's Avatar
88 coupe
Norm,
Thank you for your feedback. You may not remember, but you have provided good advise to me in the past, over on ROP. I wanted to create a unique look, since tripowers were banned by GM in 67 with the exception of the 427/435hp corvette. From a performance standpoint, I probably should have used a Victor manifold, but then I wouldn't have been able to use the stock hood. Besides, there's nothing that compares to the sound of a tripower at WOT!
Les Putnam
Old Aug 5, 2008 | 09:05 AM
cbogartjr's Avatar
Hey, great engine compartment. Really cool and unique!!! I appreciate you reply and am looking forward to your photos on how to make the louvers functional. Thanks again.
Old Aug 5, 2008 | 11:46 AM
442garage's Avatar
Carl,
Beautiful car, by the way! When my buddy Jim and I start on the hood, I will take pictures of each step involved in obtaining functional louvers. Stay tuned!
Old Aug 5, 2008 | 12:27 PM
nonhog's Avatar
Registered car nut
I am really looking forward to seeing this ! How about more pics of your car ? Could you possibly give me a measurement of those louvers ?
I am wanting a differant look for my 65 hood . And thought that would look fitting if I can find someplace to do bigger louvers ?
Old Aug 5, 2008 | 01:10 PM
442garage's Avatar
Nonhog,
As far as I know there are no local firms doing louvers. The 67 louvers are approximately 7 inches wide with two rows of 12. I don't believe any one out there has the dies necessary to do 7 inch louvers. One thing you might consider is finding a 67 hood that is shot and cutting out the louvers and grafting them to your hood. Here is a side profile of my car
Old Aug 5, 2008 | 01:26 PM
442garage's Avatar
Nonhog,
Try this link. http//www.raceace.com
Old Aug 5, 2008 | 02:25 PM
nonhog's Avatar
Registered car nut
Nonhog,
Hey thanks for the info ! any chance of being in Puyallup on the 17th ?
Old Aug 5, 2008 | 04:36 PM
442garage's Avatar
Nonhog,
"any chance of being in Puyallup on the 17th ?"
No, I believe I'm working that date. Why, what's going on?
Old Aug 6, 2008 | 08:41 AM
nonhog's Avatar
Registered car nut
Nonhog,
https://classicoldsmobile.com/forums...-aug-17th.html
Now back to our regularly scheduled thread Sorry about the hijack
cboartjr !
Old Aug 7, 2008 | 05:13 AM
cbogartjr's Avatar
No problem...that's what I love about this site...the interaction...it's great and I know someone always responds to our questions...thanks folks
orence1
Feb 12, 2015 05:09 PM
442garage
Vista Cruiser & Wagons
Feb 16, 2013 08:31 PM
OldsManNJ
Nov 14, 2012 03:53 PM
69442C
Oct 30, 2012 08:05 AM
nonhog
Jan 1, 2012 08:55 AM
