Front upper control arms
Old November 6th, 2016, 06:47 AM
ART T's Avatar
I am having trouble getting grease into my trunnions. Will I need to disassemble and clean them?
ART T is offline
Old November 6th, 2016, 07:59 AM
Trunnions?
oldcutlass is online now
Old November 6th, 2016, 08:25 AM
2blu442's Avatar
I believe the 1964 was the only year F85/Cutlass put grease zerks here. Have you tried removing and cleaned the zerks or putting new ones in? John
2blu442 is online now
Old November 6th, 2016, 08:38 AM
ART T's Avatar
Yes, I replaced them.
ART T is offline
Old November 6th, 2016, 08:42 AM
You may have to push the front end up and down while adding grease.
Old November 6th, 2016, 09:22 AM
Actually, the 61-63 cars did also.
(Yeah, the forgotten Cutlii... )
joe_padavano is offline
Old November 6th, 2016, 04:26 PM
2blu442's Avatar
Oops! I've been around a few but never owned or worked on one.
John
Old November 6th, 2016, 04:43 PM
ART T's Avatar
Thanks.
ART T is offline
Old November 6th, 2016, 05:00 PM
What frequently happens is that the old grease gets hard and won't flow out of the way when you try to put new grease in. I've had some success with backing out the grease fitting and spraying solvent (carb cleaner) in the hole, then working the suspension to loosen the old grease. Of course, once it's loose, you need to flush that solvent mess out with fresh grease. These "bushings" are the metal-on-metal screw thread type, so the solvent won't hurt anything.
Old November 7th, 2016, 03:27 AM
ART T's Avatar
Thanks, Joe.
ART T is offline
DR_DAN
March 9th, 2015 05:48 PM
197064buickspec
September 9th, 2013 09:17 PM
1971viking
November 1st, 2012 07:20 PM
oldzy
November 25th, 2010 08:27 AM
1964F85
May 8th, 2010 02:12 PM
Quick Reply: Front upper control arms
