found my rear crossmember is broke
Well I been under the culass today and found my rear crossmember is rotted and broke on drivers side and cracking on passenger side. Does anyone make a fix for these or is it a fab youself and weld it back?
That is a bad thing.
Do check your frame rails where they rise and go over the rear axle as well - there are places where you can't see rust unless you really look for it, and there can be a LOT of it.
I'm sure you can remove the body from the frame and create a new part, but if it's that bad there, the question arises: how bad is it everywhere else? and is it worth it to patch it up, rather than replace the frame or the car?
J'ville
Drivetrain/Differentials
September 4th, 2007 09:50 AM
