found my rear crossmember is broke
Old Jul 31, 2011 | 06:00 PM
dartphil's Avatar
Well I been under the culass today and found my rear crossmember is rotted and broke on drivers side and cracking on passenger side. Does anyone make a fix for these or is it a fab youself and weld it back?
Old Jul 31, 2011 | 07:37 PM
Lady72nRob71's Avatar
What year? A picture would be most helpful. If one part is rotted, others may be also.
Old Jul 31, 2011 | 07:40 PM
You mean the frame piece ahead of the rear bumper?
Or some other thing?
Check the frame rails where they rise up and over the rear wheels - check top, bottom, and sides.
Old Jul 31, 2011 | 07:46 PM
svnt442's Avatar
Are you talking about the transmission crossmember? Those should be easy to find a replacement for.
Your location would be very helpful.
Old Aug 1, 2011 | 02:07 PM
dartphil's Avatar
no it is the crossmember that the rear upper control arms bolt to right where the top of the coil spring pads rest. And upper shock mounts are located.
Old Aug 1, 2011 | 02:27 PM
That is a bad thing.
Do check your frame rails where they rise and go over the rear axle as well - there are places where you can't see rust unless you really look for it, and there can be a LOT of it.
I'm sure you can remove the body from the frame and create a new part, but if it's that bad there, the question arises: how bad is it everywhere else? and is it worth it to patch it up, rather than replace the frame or the car?
mauls
May 11, 2011 01:06 PM
tdubis
Mar 26, 2011 09:27 AM
auto_editor
Feb 1, 2011 07:43 AM
J'ville
Drivetrain/Differentials
Sep 4, 2007 09:50 AM
julius
Aurora
Sep 17, 2006 06:56 PM
