dynamic 88 to olds 98
Old Nov 16, 2010 | 04:42 PM
parkerolds64's Avatar
does anyone know if the A-frames and springs off of a dynamic 88 would fit a 98?
Old Nov 17, 2010 | 03:45 AM
D. Yaros's Avatar
This is a guess, but I would say no. 88's & 98's have different bodies, wheel bases, etc. They are not cut from the same cloth.
Old Nov 17, 2010 | 04:53 AM
jaunty75's Avatar
While I think D. Yaros is correct, it would probably help it you would tell us the year of the car you're talking about.
Old Nov 17, 2010 | 06:29 AM
Originally Posted by jaunty75
While I think D. Yaros is correct...
Unfortunately, you're both wrong.
Within the same year ranges (61-64, 65-70, 71-76, and 77-90 RWD), the Eighty Eight and Ninety Eight frames and suspension are identical except for wheelbase. The Ninety Eight simply uses a stretched Eighty Eight chassis. Of course the Jetstar 88 used the smaller brakes and wheel lug pattern from the A-body cars, but the suspension arms are still the same as on the other B/C cars.
Old Nov 17, 2010 | 06:32 AM
jaunty75's Avatar
That's par for the course for me, and it's why we have you!
Old Nov 18, 2010 | 02:36 AM
D. Yaros's Avatar
In my defense, I did say my statement was a "guess." And as has been properly pointed out, thankfully we have you, our resident expert, to get us back on the right path.
Old Nov 18, 2010 | 05:59 AM
chequenman's Avatar
The '63-'64 "A" Arm lower are interchangeable between cars but everything else was Year specific.
If you Vehicle was a Ninety Eight, Super/Dynamic "88" or Starfire your year vehicle is interchangeable with each vehicle Model Of that specific year. Hope that helps you to clarify your Question?
Old Nov 18, 2010 | 12:18 PM
Thanks for the information. my olds is a 64. does anyone know a good place to get a total front end rebuild kit? is there a place to get a catalog of the parts?
Old Nov 18, 2010 | 12:25 PM
jaunty75's Avatar
I don't think there is such a thing. You'll need to acquire the various parts (ball joints, tie rod ends, center link, pitman arm, etc.) separately and then put them on. Ditto for the brake parts if you want to redo those, too, although brake kits that contain springs and clips and pins and so forth are available. But brake shoes would be purchased separately as would wheel cylinders.
If you don't have them, you really need the service manuals for '64 Olds. That year it was a 5-volume sent, and you want all five volumes. Service manuals come up for sale on ebay all the time.
Old Nov 18, 2010 | 02:04 PM
chequenman's Avatar
Arrow
Try www.fusick.com for a lot of what you might need but for almost every thing you'll be looking for go to www.kanter.com, they'll get you fixed up...
Old Nov 18, 2010 | 02:19 PM
jaunty75's Avatar
Don't overlook your local auto parts store, too. You'd be suprised what you can still buy at your local Autozone, NAPA, etc. Fusick is very good, but it tends to be pricey. I looked just now, and Autozone's website shows all sorts of front end parts available for a '64 Olds 98 (springs, ball joints, tie rod ends, centerlink, idler arm, and more). Most of them have to be ordered, so you'd wait a day or two, but you don't pay shipping as you would pick it up at the store, and if there is a problem, you can take it right back to the store for replacement or money back.
Old Nov 22, 2010 | 08:21 AM
I have been told that to change a timing chain and timing gears I have to take the oil pan off. is this right?
Old Nov 22, 2010 | 08:40 AM
http://www.kanter.com/
The kit for your car is P/N 02365F, $239.
Old Nov 22, 2010 | 04:04 PM
chequenman's Avatar
Exclamation Naught at all!!!
You don't have to drop the pan completely, just take out the front four bolts and loosen the next six bolts on each side and pry the pan down, that will give you the room you need to pull the Timing Chain Cover off the front of the Engine. You'll need a large two or three legged puller to get the Harmonic Balancer off.....
<1963 Olds Dynamic 88 Conv>
Mar 20, 2010 11:26 AM
bobtrane
Mar 13, 2007 11:51 AM
D. Yaros
Nov 19, 2006 02:19 PM
chuck2
Jan 12, 2005 02:11 PM
