Drag links
Old Jan 23, 2008 | 03:12 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Drag links
Everyone remember to check your center&drag links for wear. I finally called it quits on mine with 149,000 ish miles yesterday. It had so much play in it that I could sway the bar side to side about 1/4'' in either direction $70 bucks later, the car feels brand new again.
A regular check well worth not losing steering and dying for.
It was a rough week for the ol' rat. It broke a motor mount in the -4 degree weather and the motor shifted 3/4'' forward and shredded the water pump and power steering belt. Alternator took a dump, #1 plug fouled, and the hot air tube on the head broke. Believe it or not the temp light came on, after 2 miles running no pump.... on a -4 degree day going 75Mph.
Sheesh, everyone keep your coolant in motion at all times, because mother nature is certainly no help at all.
Old Jan 24, 2008 | 07:23 AM
Oldsguy's Avatar
Past Administrator
The coolant could be frozen in the radiator but without any movement to the engine that thing is going to overheat eventually, convection by air won't do it.
Olds Dad
Jun 17, 2011 06:45 AM
PetChemMan
Nov 22, 2009 12:56 PM
Allan R
Sep 17, 2008 06:11 PM
delta881972
Jul 4, 2008 11:03 AM
Patrick
Feb 26, 2007 12:07 PM
