couple questions
Old May 14, 2012 | 06:55 PM
raw442's Avatar
Question couple questions
Right off I have a 1969 442.
1st, my transmission hump has a pretty good size hole (factory) on the driver's side up close to the gas pedal. What is this? Did my car have those multiple shifters on the transmission? And what were they called?
2nd, I discovered my radiator support is rusted on the driver's side pretty bad. What years interchange?
3rd- What frames 68-72 interchange on this body style style?
Thanks ahead of time!
Old May 14, 2012 | 07:43 PM
A photo would help. There should not be any holes "up close" to the gas pedal, but up close is a relative term. There was only on factory floor shifter for the AT. Could have had an aftermarket shifter at one point.
1969 or 1969. Unfortunately core supports are one-year-only for the 1960s and early 1970s.
We'll tell you when you tell us what body style you're talking about...
Old May 14, 2012 | 08:44 PM
1. take a look at this link: pages 210 and 312 should help you determine that hole. http://wildaboutcarsonline.com/membe..._-_Sec_1-5.pdf If it's a 69 442 it had a console with either an AT or SMT
2. Joe got that covered.
3. You can interchange any 2 door 68-72 Chevelle, Cutlass, GTO/T37/Tempest or Skylark frame. Since it's a 442 - it will automatically be a 2 door. Do you have a post coupe or a hardtop coupe?
Old May 14, 2012 | 08:53 PM
Originally Posted by Allan R
... You can interchange any 2 door 68-72 Chevelle, Cutlass, GTO/T37/Tempest or Skylark frame.
... Unless it's a convertible .
Old May 14, 2012 | 09:25 PM
Originally Posted by MDchanic
... Unless it's a convertible - Eric
Touché my friend! Point taken.
Well if its a 442 vert, that narrows down the options again doesn't it?
Old May 15, 2012 | 03:42 PM
Which would be why I made the comment in my original post...
Old May 15, 2012 | 06:59 PM
raw442's Avatar
My car is a 2 dr. hard top (no post). Here is a pic of the hole.
Also are my fenders also year specific?
Tvan
Apr 10, 2012 02:06 PM
bigde53
Apr 6, 2009 10:14 PM
1973oldsomega
Mar 23, 2009 08:31 AM
74omega
Drivetrain/Differentials
Jul 7, 2008 09:46 PM
Rallye469
Mar 24, 2008 09:29 AM
