Control arm anchor bolt HELP
Hey all! I am in the process of replacing my control arm bushings/ball joints and have run into a little problem. While removing the upper control arm, I noticed that I dont have room to remove the arm off of the anchor bolts (ie alignment bolts), due to being so close to the header on the passenger side, and the steering column on the drivers side. I was wondering if anyone could tell me if the bolt itself could be removed out of the frame? It is hex head on the outer side but it doesnt budge. Im assuming that they are pressed in so that they dont turn during alignments? Any help would be GREAT!
The Chassis Service Manual shows the use of a pry bar bearing on a block of wood against the exhaust manifold. Unfortunately, if you have headers this may collapse the header tube (do NOT ask me how I know this... ). Be sure to thread a nut loosely onto the bolt to avoid bunging up the end threads while doing this.
If you can't get a pry bar on the end, use the nut and try tapping back and forth with a hammer to loosen.
Go to harbor freight, get a big c-clamp- have a friend with a mig welded weld on old socket(upside down) (or block of metal or something solid) on one end so it can curve under the steering arm... then put a loose socket over the head under the mounting arm, and tighten the clamp. It will pop right out.
This can also be done with the same giant c-clamp and ducttape holding a block onto the end, but its a heck of a lot easier if its actually permanendtly connected to the c-clamp and won't slide around.
Thanks for the replys! Rambow-I like the c-clamp idea. Ill give that a shot, and Joe, I had thought about that when Maniac said that they were removable. That was my main concern, making sure they would come out. I guess its just gonna take a little more *** to do it!
MrGasser
June 18th, 2014 12:34 AM
Tony72Cutlass'S'
July 9th, 2012 12:08 PM
oldzy
December 19th, 2011 06:43 AM
