Cleaning inside boxed frame
Old Mar 18, 2014 | 11:08 AM
nonhog's Avatar
Registered car nut
Have an A body frame I am messing around with, so far I have dug out the dirt and grease I could get at. Then pressure washed the outside and inside
(the best I could) Seems everytime I thought I was getting close a few new clumps would break free.
Never ending supply of dirt and grit.
Thinking about sealing holes and flooding with the hose since the pressure washer only seems to be good for angles it can get at.
Wondering what has worked for others?
Old Mar 18, 2014 | 09:09 PM
nonhog's Avatar
Registered car nut
having fun now!
Old Mar 19, 2014 | 05:06 AM
Seff's Avatar
That's an odd frame. It seems to be wider in the middle. Is this a standard boxed convertible frame?
Old Mar 19, 2014 | 08:23 AM
nonhog's Avatar
Registered car nut
Its a 67 El Camino frame. They are boxed just like a convertible or performance models.
Which is what makes it so much fun to clean out. LOL
Old Mar 19, 2014 | 10:12 AM
Seff's Avatar
It looks nice.
I'd get some sort of detergent/cleaner and mix it in with the pressure washer. Other than that, I'd rely on undercoating to be applied in liberal amounts to the inside of the frame.
Old Mar 20, 2014 | 03:17 AM
Yellowstatue's Avatar
You could send it to a metal cleaner such as Redi Strip... they can do complete car bodies as well. Their tanks are eight feet wide and about ten foot long. Another alternative is to have it galvanized. It gets soaked in an acid bath for a while then tenderly dipped into molten zinc...almost like doing chicken!
Old Mar 20, 2014 | 03:54 AM
boese1978's Avatar
After doing as you are doing, I used a wet/dry vac and sucked all the left over sand, dirt, crap........
Old Mar 20, 2014 | 09:02 AM
nonhog's Avatar
Registered car nut
Wait what? you cook chicken in molten zinc?
Actually the last frame I did I had sand blasted. I have had a body acid dipped. Not in the budget this go around.
WTony
Apr 22, 2015 11:30 AM
OldsMotion
May 7, 2013 05:55 AM
Olds luvr
Dec 2, 2010 08:26 AM
carmax
Oct 5, 2009 07:47 AM
J-(Chicago)
18
Jun 10, 2008 04:37 AM
