boxed lower control arms install
Old May 27, 2017 | 06:48 AM
bassinguy's Avatar
I am installing boxed LCA on my 65 Cutlass. When do I do a final tighting of the bolts? Do I tighten them while car is in the air (no weight) or after it is on the ground(with weight)? Thanks for any and all help. Bassinguy
Old May 27, 2017 | 06:56 AM
I leave them snug, lower the car and then support the car by the rear axle. This gives me more room to move around.
Old May 27, 2017 | 06:59 AM
All rubber suspension bushing bolts MUST be torqued only when the full weight of the car is on the springs and the suspension is at ride height. At the rear this is easy - just put the jack stands under the axle tubes.
Old May 27, 2017 | 07:03 AM
bassinguy's Avatar
LCA install
Eric and Joe Thanks for the quick response on how to tighten. I will be doing this later on today. You guys are great with helping other guys with their cars. Joe do you happen to know the torque values? Again Thanks Bassinguy
Old May 27, 2017 | 07:13 AM
All of the rear control arm bolts are 80 ft-lb
Old May 27, 2017 | 07:17 AM
bassinguy's Avatar
Lca
Joe Thanks again Bassinguy
66-3X2 442
Oct 4, 2011 09:13 AM
JSGD1966
Oct 5, 2010 08:26 PM
tim72
Drivetrain/Differentials
May 25, 2009 08:24 AM
hamm36
Suspension & Handling
May 23, 2009 09:55 AM
