Bolt grades to use for rebuild
Old Jul 15, 2010 | 08:25 PM
86 Cutlass's Avatar
Does anyone know what a 10.9 metric equal to in std hardness? Grade 5 or 8? We are rebuilding a 86 Cutlass Supreme and started to use grade 8 for all of the upper and lower control arms, and A arms, but someone told me that the grade 8 were brittle and would break from the vibration? We had to cut a lot of the original bolts for removal. Any help would be great.
Old Jul 15, 2010 | 09:32 PM
henryk8398's Avatar
Hangin' out...
This may help...
http://www.dansmc.com/torque_chart.htm
Old Jul 16, 2010 | 05:41 AM
Lady72nRob71's Avatar
Looks like grade 8 is similar to 10.9. If I was you, i would just use all grade 8. Tractor Supply sells it by the pound!
The harder a bolt is, the more brittle it would be, but it would take a heck of a lot to break them.
My 72 uses grade 8 for the suspension and the 86 chassis design is not a while lot different.
Old Jul 16, 2010 | 07:36 AM
Yeah, so long as all you need is coarse thread. I needed 7/16 fine thread grade 8 bolts for the seatbelts in my 62. I had to get them from McMaster Carr.
Old Jul 16, 2010 | 08:50 AM
My 72 used coarse threads, so I lucked out and the threads were the same, new and old.
Old Jul 16, 2010 | 09:00 AM
Originally Posted by 86 Cutlass
...but someone told me that the grade 8 were brittle and would break from the vibration?
Brittleness goes with hardness, not necessarily strength. In addition, vibration causes fatigue failure, which is completely different from a brittleness failure. Bottom line is that the factory bolts are Grade 8 (or equivalent metric). Anyone who says not to use Grade 8 in any application due to brittleness does not know what they are talking about.
JpMotorsports
May 15, 2014 07:08 AM
Jrod
Mar 22, 2013 05:01 AM
442dreamer
Aug 23, 2011 07:28 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
