Body work questions - I'm in way over my head here!!!
Project is starting all wrong.
First Question - 5 out of 8 of my body mount cage nuts are spun. Is my only option to cut the floor pan and trunk?? Is this a common problem?
Second Question - My RH front body mount has collapased allowing the body to sit directly on the frame. The rubber body/frame mount cushion is actually inside of the body mount with a chunk of metal bolted to it. Any ideas for a fix would be greatly appreicated. Any idea other than the obvious - Hire a professional! Thanks in advance.
68 442 convertible - Louisville, Ky.
ATrain1
Non-Olds Engines
June 29th, 2012 12:58 PM
