Body mount shims to fix door vertical alingment?
I'm re-assembling a 70 cutlass convertible from a full frame off restoration. The body fits great, I have the doors on, but now I have slightly larger gap at the top of the doors at front fendor. the bottom, and rear fit nicely. I've heard that you can correct this with body mount shims, any idea if this is feasable? It is possible that the new body mounts are slightly different from the original equipment, causing the change in door alignment. (see image attached) Any ideas appreciated!
coppercutlass
August 5th, 2014 01:10 AM
Al Sanchez
March 10th, 2014 03:36 PM
