Ball joint quality
Old Jan 15, 2017 | 05:29 AM
lonestarjarhead's Avatar
Ball joint quality
Has any one used XRF brand ball joints? Their website makes them sound good, but it really never says they are USA made. Found a pair of lower USA Moogs for Vistacruiser through Oreillys, but are $124 each.
Old Jan 15, 2017 | 05:51 AM
Moog ball joints on Rockauto are $18.10/upper and $20.79/ lower.
Old Jan 15, 2017 | 06:44 AM
I don't understand why people don't take the time to check prices on RockAuto. Even if you don't want to buy the parts there, at least see what pricing looks like. The classic example is the Anchor/Pioneer motor mounts. Vendors sell these (in the original Anchor or Pioneer boxes) for $35 or so each. RA sells them for about $4-$7.
Do, however, be aware of errors in the RA listings. As an example, for a while they showed the Vista as using the ball joints from the full size cars, which is not correct. Vistas are A-body cars like any other Cutlass of the same year. The correct Moog part numbers are K5103 and K5108.
Old Jan 15, 2017 | 08:18 AM
Yeah, I know that they sell Moogs a lot cheaper than $124, Oreillys does also. The problem is that Moog products are now produced in more than 12 countries, including China. So you don't know what you're getting until you see the box, or maybe it's stamped on the product. Even then, items are sometimes re-boxed. Trying to get away from Chinesium.
Old Jan 15, 2017 | 10:54 AM
D. Yaros's Avatar
While this is good advice, my experience with RA is that one needs to factor in shipping charges to arrive at the "real cost."
RA charges a separate shipping charge from each warehouse location. So theoretically one could order 2 ball joints and ea ships from a different warehouse and carries its own, separate shipping charge.
Old Jan 15, 2017 | 11:07 AM
While the shipping charges may sometimes be a factor, I've found that they have been the least expensive. I try and buy local and American made as much as I can, however there is a percentage of the increased cost that I am willing to absorb. I also look at Amazon as a prime member there is free shipping and usually the part will arrive in 2 days.
Old Jan 15, 2017 | 01:10 PM
Of course you need to do this, but here in northern VA, the RA shipping costs are usually a wash with the local sales tax. Once you select an item, RA also highlights items that ship from the same warehouse to minimize total cost.
Old Jan 16, 2017 | 10:20 AM
oddball's Avatar
If that's your true goal, then convert to Howe adjustable/rebuildable ball joints. They are pretty amazing, and truly USA designed and made.
SC&C sells them with much better dust boots. The boots direct from Howe don't work very well.
I'm pretty certain there's no stock application suspension part made in U.S. Aftermarket versions (e.g., tubular arms), sure. But stock replacement? No. The guys are Proforged wrote a good post on another board about the true supply chain.
XRF doesn't advertise manufacturing location anywhere, but obliquely mention "manufacturing partners". Maybe it's a better ball joint than a MOOG, maybe not.
Old Jan 16, 2017 | 10:37 AM
Run to Rund's Avatar
A body lower ball joints are press-in and so replacements will be oversize. Since the cars are about 50 years old, some replacements are double or triple oversize. Mike the joints and try to find the next size needed; they will press in a lot easier and leave room for a future rebuild.
Old Jan 16, 2017 | 01:30 PM
I've found this too.
I also use that information to throw back parts that could be selected from compatible warehouses. Shipping costs from RA are very affordable IMO and on par with Inline tube.
Momma always said to shop around if y'all want the best deal. That's incredibly true, but most peeps lack the motivation or knowledge to do that and take the first thing they find, regardless of price. Then, they bitch about it. This site has lots of good info about parts suppliers - good and bad.
KQQLCAT
Suspension & Handling
Jan 13, 2010 07:42 AM
f85mark
Nov 30, 2009 12:13 PM
70vista
Nov 19, 2009 05:54 PM
scrappie
Sep 7, 2009 09:45 AM
IDAS 69
Jun 27, 2009 07:36 PM
