B-body with double exhaust over the 4link rear axle
Old Jan 26, 2015 | 08:12 AM
Oldsragger's Avatar
I can only find 1 side (example right) with the correct bend that will go between the upper controll arm and and the spring... but i found this type on summit racing and ebay... but the curves is not the same.... have some one experince with this pipes over the rear axle with 4link and spiral springs?
The last pic here is like the orginale curve i guess.... but i should have right and left side.... i will see if rock auto have something.....well its always possible to weld togeather a copi..
Old Jan 26, 2015 | 08:29 AM
Professur's Avatar
Have you looked into just having a local muffler shop put together a system for you?
Old Jan 26, 2015 | 08:58 AM
Oldsragger's Avatar
Yeah,but they dont have that big bend that is on the top, i have a pipe bender but its not good to use, im woundering to just buy one for the side and take it with me to a muffler shop and see if they have parts and have something to make a mirrowed copy.
all i need is that bend over the axle, the rest i can make self if nessesary.
OR just buy two in same side and just cut off and twist it mirrored bends and weld together....hmm maybe thats a better idea.
have search for many models now on rockauto but looks almost everyone have only single pipe. i found a nice dual kit on ebay with rigth curves, but very expencive.
well i will just email them and ask if they have something that can fit anyway.
Old Jan 26, 2015 | 12:07 PM
The Stickman's Avatar
If you can weld just get yourself some bends and make yourself a pipe. I have done this before. Just figure out each portion a lttle bit at a time cut weld and move onto the next portion. I bought a kit of different Mandrel bends off Ebay and ended up with a nice exhaust system front to back.
Old Jan 26, 2015 | 12:12 PM
Oldsragger's Avatar
Oki, yes i think i need to do that. I can always make bend me a model in brake lines first, then build it from that model, but i guess i Will buy at least one side finished, maybe two of the same and just cut it up, turn the parts in mirrowed direction and weld it.
Old Jan 27, 2015 | 07:53 AM
The tail pipes for a 1991-96 Caprice/Impala with dual exhaust will fit your car. Here is the stock 2" exhaust with the Walker part numbers:
There is also a Dynomax 2.5" system, shown here:
Rockauto sells these parts.
Old Jan 28, 2015 | 03:56 AM
Oldsragger's Avatar
This is perfect Joe! thanks a lot
Old Jan 28, 2015 | 04:26 AM
Oldsragger's Avatar
Im searc for the part nr 54015 and 54014 on ebay and find the parts.. but i see in the decription it stand "aluminized steel "
what they mean with that? is it steel pipe with aluminum look? or is it just a protective coat on the top ?
i should have steel so i can weld if i need to modify it in the tail tips..cause i cant weld aluminum.
EDIT: i order the 54015 and 54014 anyway.
Old Jan 28, 2015 | 05:30 AM
Aluminized steel is steel with an aluminum coating that resists rust.
You can weld it.
Old Jan 28, 2015 | 05:33 AM
Oldsragger's Avatar
Ok, i guess it will make a toxic gas if i dont remove the coat first a little on the places i will weld if so.
Old Jan 28, 2015 | 08:15 AM
You are thinking of the zinc in galvanized metal coatings. The aluminizing is really just pure aluminum that is flame sprayed onto the steel as a rust preventative coating. You do need to remove the coating where you will be welding, but that's to prevent contamination of the weld. It doesn't give off toxic gasses.
Old Jan 28, 2015 | 08:20 AM
Oldsragger's Avatar
yeah i mean the galvanized coat, ok so the aluminizing is another thing then.
well sounds not bad anyway, i think its a ok product,, the brand name Walker.
CLcutlass
Paint
28
Feb 6, 2020 05:57 PM
BackInTheGame
Jun 8, 2013 07:50 AM
cutlasssupreme71
Drivetrain/Differentials
Feb 22, 2011 11:40 AM
74omega
Nov 30, 2008 04:09 PM
shaks 442 clone
Feb 17, 2008 04:55 AM
