All New Suspension
Old Nov 22, 2014 | 07:12 PM
Convertcrazed's Avatar
All New Suspension
I'm shopping for all new front and rear suspension for my 1970 CS that I'm building into a 442 clone (nice driver)........just looking for some suggestions on what brands are best.....aka moog, raybestes, acdelco, ect????? And also where to buy....looks like rock auto beats ebay?. I also want to go up instead of down, so back in the day, I remember hearing that if you put BB springs in front, it would add some lift? and station wagon in the rear it would do the same? Just don't want to mess up the ride, like I did 30 yrs ago with spacers in the front and air shocks in the rear LOL!!!! I don't want to afford $$$$ adj coil overs....figured I can do it with the right springs....also plan on several trunk loaded trips, so should I buy the progressive springs for the rear?
I'm also planning on adding a rear sway bar....OEM? Looking for a 1-2" level lift......not a jacked up hot rod
Thanks for your input!
Eric
Old Nov 25, 2014 | 09:15 AM
My suggestion is to put in factory 442 springs as they should be 1" shorter ride height than the Cutlass Supreme springs.
My suggestion:
Moog 5536 up front
Moog 5409 in back
Buy Moog bushings, ball joints , tie rod ends, etc. from your local parts house, Rock Auto, or wherever has the best prices. It doesn't take long to shop around online.
Here's some front spring info from an old post:
> 5390 small block - no AC
> wire diameter = 0.650"
> load height = 11.000"
> load = 1952 pounds
> rate per inch = 336 pounds
> free height = 16.808"
> 5382 big block - no AC, small block - AC
> wire diameter = 0.660"
> load = 2066 pounds
> rate per inch = 360 pounds
> free height = 16.724"
> 5400 big block - AC
> load = 2167 pounds
> free height = 17.004"
> 5536 442 small block - AC - heavy duty, 442 big block - no AC - heavy duty
> wire diameter = 0.690"
> load = 1984 pounds
> rate per inch = 488 pounds
> free height = 15.063"
> 5450 small block - AC - heavy duty, big block - no AC - heavy duty, -442 big block - AC - heavy duty
> load height = 12.000"
> load = 1642 pounds
> rate per inch = 454 pounds
> free height = 15.616"
Old Nov 30, 2014 | 05:57 PM
Thanks Ken,
Well I bought all new suspension from rockauto....I got 5536 for front and cc503 for rear.....I hope I did right? I figure if it's to much for the rear? I can cut down?
Also got all new moog bushings and ball joints
Eric
Old Dec 2, 2014 | 11:06 AM
69455's Avatar
Cant say enough about my Detroit Speed Kit 3 front and rear.
Single adjustable coil over.
Tracks like a slot car
Still run's 11.5 1/4 mile
firefrost gold
Hurst/Olds
Jul 14, 2011 05:59 PM
DAN76
Jun 14, 2010 02:01 PM
BIGJERR
Jan 11, 2009 05:46 PM
BIGJERR
Nov 26, 2008 04:21 PM
Oldsmofjord
Jul 23, 2007 05:24 AM
