72 core support
Old Apr 10, 2013 | 03:31 PM
Austin Trevor White's Avatar
72 core support
Working on replacing the core support on a 72 cutlass. I found one for sale that's fits a 70 cutlass. Are these interchangeable? Thanks.
Old Apr 10, 2013 | 03:59 PM
gearheads78's Avatar
car guy
No 72' is one year only but a 71' could be modified with a little work.
Old Apr 10, 2013 | 04:06 PM
Although I agree, I guess it would be a good idea to ask what type of grill is going in? If it's a 442 grill either the 71/72 rad supports will work. But if he's installing the eggcrate (CS) grill or horizontal bar (Cutlass/S) grills it would be better with the 72 rad support instead of cutting notches for the grill edges to fit into.
Austin - the 72 model year grills were moved forward and up which required a peak on the rad support close to the headlights. The 1970 models have a completely different rad support and grill/headlight fastening system that is not interchangeable with 71 or 72.
Old Apr 10, 2013 | 07:40 PM
it's a horizontal bar grill for a cutlass. I haven't had much luck finding one. I'd prefer new, does anyone know of anyplace that sells theses or maybe patch pieces. mines all rusted out where the battery sits.
Old Apr 10, 2013 | 07:57 PM
The battery tray area of the rad support is a notorious location for rustout. The 72 rad support is not repopped so the only way to get another is to find someone who's parting out the car. The rad support can be from any of the 72 Cutlass models: Cutlass, Cutlass S, Cutlass Supreme or Vista Cruiser.
Some folks on this site who part out cars and may have what you're looking for:
John McNeel (2blu442) Medford OR
Eric Jensen (jensenracing77) Brazil IN
Brian Trick (507OLDS) - Erie PA
Scott Winn (oldspackrat) Indianapolis IN
There may be others who have the parts; but I know these guys usually have a lot of things others don't.
Are you also looking for the horizontal Cutlass Grills? Wasn't sure if that was what you were saying in the post.
Old Apr 10, 2013 | 08:02 PM
no my grills are fine. you had just mentioned that depending on the grills i have it makes a difference on which core support will work and i was just clarrifying what exactly i had.
Old Apr 10, 2013 | 08:22 PM
Got it. If you're going for the OEM look, you will need the 72 rad support. Do you have any fabrication or welding skills that would let you repair the damaged area? Maybe someone you know does? Those 2 little bumps on the leading edge are necessary for the grill to fit properly.
What's your location?
Old Apr 11, 2013 | 08:38 AM
kitfoxdave's Avatar
I had a 71 support that i picked up from a member and cut out the bumps from a 72. A buddy welded them for me, looks good as new... Going into the car in about a month...
Old Apr 11, 2013 | 09:25 AM
NHolds's Avatar
My dad has a 72 core support up in his attic. I doubt he would ship it though, where are you located. He is in OH
jensenracing77
Jan 25, 2018 04:16 PM
rcktdoc
Jul 14, 2014 12:38 PM
esisson
Jan 14, 2007 04:38 PM
8valve
Dec 3, 2006 03:29 AM
