71 Cutlass front wheel cohesion
Hi,
I hope i post this in the correct place, and you will understand my problem.
For me it is a bit difficult to describe it. The car is like "drifting" on the road, and you have to steer all the time to run it straight. I think there is something with the wheel cohesion (if this is how you call it...).
I tried to adjust it, but i don't know how much should be the difference between the front and the back distance between the 2 front wheels. I set it to have a bit less distance in the front, but i can test it only tomorrow.
(I checked all the other parts of the steering system, and everything seems to be good.)
If you have any ideas to set it right, please let me know!
thanks,
Balage
thanks,
Balage
Hi,
thanks,
Balage
thanks,
Balage
Yep, sounds like caster or a worn steering gear.
The consensus from all I've seen seems to be +1-1/4 degrees positive caster, minus -1/4 degrees negative camber and 1/8" toe-in.
I just went through the same thing and ended up doing the box, they started getting loose soon as you pulled out of the new car dealer's lot to take the car home back in the day.
CutlassS1972
Body work
Aug 21, 2014 09:06 PM
costpenn
Apr 11, 2012 07:25 PM
1k442
Sep 8, 2010 07:16 AM
