71-76 Full Size body mounts
Sorry to bring up a thread from a month ago, does anybody have a link where you can find the GM 71-76 fullsize frame bushings + bolts (generic GM item)? Thanks all!
I did all new body mounts on my black 98 when I did the frame off and I have the part numbers at home. I should be able to get it to you soon. I don't have the bolt part # but that is probably fairly generic I would think. I was able to clean up and re-use my bolts.
Resurrecting an old thread on a different topic (Cutlass body mount bolts) is probably not the best way to get a good answer about full size car rubber body mounts. Here's a dedicated thread for you.
My number 6 position bushings have all dried up, after doing some googling found this: http://www.gmpartswiki.com/getpage?pageid=97890
Energy Suspension has some kits and I ended up with 91-96 Impala kit 3.4145, I hope one of them is the correct size.
Hey, I snapped a pic from my service manual where I wrote down the part numbers of the body mounts. Mind you, this is from a while ago and these may not all be available anymore. Even at the time, some were discontinued and I had to improvise.
I hope this helps.
I like Metallica & big olds too. I'd also like those body mount part #s for my 75
Hey man, I love that you're an Oldsmobile AND Metallica guy...right up my alley!!
75 delta 88 body conv mounts
I am looking to replace body mounts on 1975 delta 88 convertible. I had a box of moog bushings, I bought in 1999-2000, but where misplaced/lost. If I had a brand and part #, maybe web search would turn something up. I assume the impala bushings are same, but classic industries, etc don't have em. Thanks for response.
71-76 full size body mounts
FYI. The parts place has a kit # hb2855p pH .630- 365-1800 for Chevy impala 71-76. it is same, so they tell me. $249.99 , 26 pieces. I found it yesterday. They are reproductions of original. I have not bought yet, I decided to deal with brake lines 1st. I will buy in a coupla wks I'll post update then. Person I spoke with at parts place didn't seem he wanted to be bothered when I asked about product. Whatever was on his screen was all he offered. Hope this helps
Body mounts
No , my car is still off the chassis.
I have been working on the bottom of the body off and on removing undercoating, etc to hopefully paint the bottom of the body. This is between working overtime, and other projects.
I am 16 1/2 months to retirement, I plan on having the time then to finish if how I want .
I wont buy the mounts till I'm ready to put it back together. Also, the attitude I got from the guy on the phone when I called for them soured me. This was a few years ago. I was hoping to find them somewhere else.
On the other hand I did ebd up buying some parts for our Trans Am from them, and that went well.
Until then I will keep buying every big 71-76 Olds I can get my hands on and parting them to finance this debacle.
Good luck and stay healthy.
Jim
Jim
