56 88 hood removal
Old Jun 24, 2008 | 10:53 AM
kaptmikey's Avatar
56 88 hood removal
Help, I'm trying to remove my hood on a 1956 Olds 88. How do those pins on the hinge come out? Thanks in advance. Mikey
Old Jun 25, 2008 | 03:01 AM
88 coupe's Avatar
Junior Member
Those "pins" should be rivets.
Find the bolts that hold the hinges to the hood. Far easier to remove.
Norm
Old Jun 28, 2008 | 11:22 AM
kaptmikey's Avatar
hood bolts
Norm,
Thanks, but are you saying to remove the rivets and use bolts? Or to take the hood off by removing the whole hinge assembly? What about the hood springs? How do you remove those with damage control? Thanks Mikey
Old Jun 28, 2008 | 04:27 PM
citcapp's Avatar
Originally Posted by kaptmikey
Norm,
The spring assembly stays with the car. The should be a plate on top of the spring assembly with two 9/16 nuts and washers holding the plate to the hood. Both sides are identical. Two people are best for the removal of the hood
Kevin W
Body work
Sep 19, 2012 09:17 AM
jdana24
Dec 18, 2011 04:20 PM
defiant1
Body work
Dec 19, 2010 06:58 PM
georgiaboy697
Jul 2, 2010 09:23 PM
mmurphy77
May 14, 2010 08:13 AM
