55 front coil spring installation
Old Mar 27, 2015 | 07:13 PM
Olds Scott's Avatar
Got all my A arm front axle bushing installed, now want to install components with coil springs. Problem is that engine and trans installed but have all the front sheet metal off for easy access. Can the springs be assembled with out reassembling the front sheet metal?
Old Mar 27, 2015 | 07:25 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Sure they can. It should be a lot easier.
Old Mar 27, 2015 | 07:37 PM
It'll give ya some extra elbow room.
Old Mar 27, 2015 | 08:00 PM
Olds Scott's Avatar
Glad to hear, was afraid the spring might overcome the front end weight with the sheet metal. Could also use a good spring compressor to take some of the tension out of the spring when lifting lower A with hydraulic jack
Old Mar 27, 2015 | 08:13 PM
You can put a couple of sand bags on the front...
Old Apr 11, 2015 | 05:15 PM
Olds Scott's Avatar
Got the drivers side spring in today all by myself. Had to use a spring compressor along with floor jack and a lot of maneuvering. Get the other side in tomorrow
wisniows
Nov 25, 2014 05:53 AM
442iowa
Suspension & Handling
Feb 13, 2012 05:05 PM
boese1978
Dec 18, 2011 06:41 AM
77GCSX
Jan 25, 2011 02:53 AM
Longhorncutlass
Mar 2, 2009 01:53 PM
