1971 Cutlass Hood Lock bolts
Old Jan 13, 2020 | 01:10 PM
72cuttys's Avatar
Could someone provide me a picture of how the hood lock is mounted to the core support? And also the bolt size I'd need. I have misplaced them. Car is a 1971 Cutlass S.
Old Jan 13, 2020 | 07:48 PM
70Post's Avatar
Are you talking about JUST the three bolts that hold the actual hood lock to the large top metal surface of your core support. If so, there will be THREE 5/16" hex flange bolts used. OR....if you have the remote hood lock option, it uses TWO 5/16" hex flange bolts and ONE hex flange nut.
Thread length on the bolts is approx 3/4" or so.....these are the same or extremely similar to the bolts that hold your radiator top plate to the core support...just pull one of those and you'll see that they work on the hood lock as well.
These are regular machine threads...not coarse/sheet metal type threaded bolts.
To install the hood lock you need to "fish" it into place from UNDERNEATH the top surface metal of the core support. Put the main upper part of the lock up through the rectangular hole in the middle of your core support top flat metal area and install the bolts or bolts/nut.
Old Jan 14, 2020 | 05:36 AM
72cuttys's Avatar
Thanks. I think I found them actually. I must've tossed all the bolts from the core support into the "radiator top cover" baggie! Slowly but surely my car is coming back together.
72cuttys
Sep 27, 2019 08:24 AM
costpenn
Feb 26, 2014 09:54 AM
JuzCallMeDee
16
Feb 11, 2013 10:31 AM
paul879
Jan 23, 2010 05:28 PM
72rocket
Oct 18, 2007 10:06 PM
